Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
I should have a Mac version when the public SDK for Mac is available. It should be a matter of weeks, they're working on it at Eovia. I'll have also the Mac version of Deeper and Baker around the same time. And I understand a tool like Replica was needed. Since I have it, I play a lot with it. Just a few clicks and I've got a complex scene! Julien
Here's something I forgot to do: the tutorial was made with a beta version. In the release, the build-in noise has a greater amplitude than before, so to reproduce the tutorial, the scaling values should be lower to about half of the displayed values. I'll update the screenshot later. For the grayscale shader, you can use a Carrara environment shader, or a vertical gradient. The one I used is in the Veloute plug-in.
Thanks Julien but you have raised a huge list of questions. These may be best answered if you could show screen shots of EACH of the three grayscale alternative and of the two numerical settings thingumies of the app for the trees. Having problems with the Replica trees being elevated above the landscape. This (will!) be the best Carrara add on ever I think.
bwtr
The scaling is relative to the hotpoint, so it's really important to place it at the base of the tree. But if this is done, the trees shouldn't be elevated over the ground. They can look elevated in the real time rendering because the terrain use a lighter version of its mesh to be displayed, but the final rendering should be fine. Can you send me your file before the replication is done and the parameters you used if you still have a problem, I'll look at it. And I'll update the tutorial this week end and put the scene and the shader available for download.
Send me the file at julien_chaplier@yahoo.com, I'll check it. I need to know where the problem is coming from. And I had trouble downloading the new file from the website, the wrong one was in the internet cache and I needed to erased it to get the new one. Plus it's a C4 file, I'm not sure you can open it with C3.
Attached Link: http://julien.chaplier.free.fr/Main.html
Hi everybody, I just added a new plug-in online : Replica. Replica duplicates objects in various configurations. The duplicatas can follow lines, squares, circles, or any kind of existing shape in the scene. Furthermore all the new instances can be sligthly different from the others in position, scaling, orientation and even shading. When the object is a light, its color can be modifed. The modification is by default a build-in noise, but it can also be based on any shader present in the scene. You can find more information on Replica on http://julien.chaplier.free.fr/Main.html . Regards, Julien
