Message edited on: 11/09/2004 00:59
I used the atmosphere to do this. But the more lights you have, the more difficult it will render. My version only has to 2 lights (for the green lights, because the render used more lights) I placed the first light, then load the second. Instead of placing manually the second light, i made ctrl-c on the first light and ctrl-v on the second. And then changed the second light rotation. Last but not least: with Poser5 (and Poser4 ?), you can change the maximum of each value. Giving the value 180 to angle_start and angle_end will create something like a point light (the trick is from Ynsaen, if i remember well) And another trick to reduce the difficulty is to decrease the map size of the light you use (as it is for a "big" scene, a low value should be enough. Hope it helps.
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=290371&Start=1&Artist=ChuckEvans&ByArtist=Yes
I know it might not be a good suggestion but you might consider Vue 4 (at a really great price now). I'm not very good in 3D stuff but was able to make a "reasonable" image with a lot of lights (inside and outside) sort of like what you are trying for in the attached image. WOrking with lights in Vue is very easy!This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
