Sat, Jan 11, 4:25 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 10 10:15 am)
Carrara Free Stuff here.
Subject: Glass shader and visible edges
Parkie ( ) posted Tue, 16 November 2004 at 2:28 AM ยท edited Thu, 02 January 2025 at 12:13 PM
Hi, I have been playing with this model which I created in the spline editor. When I apply a smoke glass shader to the part and render it, there appears to be a slot in the model around the candle. See circled area. using a solid shader this does not appear. Is there a way to have the top glass ring not to be so transparent or should I have created this part another way?? rendered with transparency and light through transparency active. Nicholas86 candle shader works well. I am not really happy with the flame yet, too bright. Created in Carrara 4 Pro Any helpful tips would be appreciated. Cheers Neil
Hoofdcommissaris ( ) posted Tue, 16 November 2004 at 2:49 AM
I think the 'hole' in which the waxine candles are set, should be attached to the lower part of the thickness of the table top (huh? I must read that again). i.e. the outside of the glass cilinder should not go to the top of the top. And maybe you should try of another refraction value is needed. But I think it is a matter of adding an extra cross-section and take the real-world construction in consideration. I might very well be wrong, but it is the most logical explanation (not the most logical way of trying to explain it probably ;-)
Parkie ( ) posted Tue, 16 November 2004 at 3:03 AM
Now that is worth a try. I only saw the candle holder for a quick glance in passing and thought that it looked interesting. I did a quick sketch on my palm but missed out details. While I initally thought the top was below the candles, I'll try it the way you have suggested and see. Thanks for the quick reply . Cheers
sailor_ed ( ) posted Tue, 16 November 2004 at 12:29 PM
If I understand the problem you might try making the candle just a little smaller than the hole.
falconperigot ( ) posted Tue, 16 November 2004 at 5:18 PM
The simplest way of getting rid of this is to duplicate your spline glass object, delete all the cross-sections except the 'top' ones and then edit a duplicate shader for this so that the transparency is less and reflection greater. You'll need to reduce the size a tiny bit as well otherwise you get the result in the lower of my two pics. HTH Mark
mdesmarais ( ) posted Tue, 16 November 2004 at 7:59 PM
A fresnel shader might help a little too- maybe some sort of environment around it (hdri, etc) so there is something to reflect. Markd
Parkie ( ) posted Wed, 17 November 2004 at 12:25 AM
Thanks Mark I will try that. Your picture (top) is what I was expecting to see when I first rendered it. Markd, I have not purchased the fresnel shader plugin yet but thanks I'll have to have a play with that one day. Cheers Neil
mdesmarais ( ) posted Wed, 17 November 2004 at 6:46 AM
Shader ops Fake Fresnel would do it too. . . Really the same effect as Mark is talking about- just that the shader is aware of the angle of the surface being rendered. The environment comment stands either way- giving highly reflective materials something to reflect makes them much more realistic. Good Luck! Markd
Parkie ( ) posted Thu, 18 November 2004 at 2:33 AM
Thanks Markd, I've printed this thread to PDF so I can refer to it while I play. Cheers Neil
