Fri, Jan 24, 10:28 PM CST
Subject: Glitch in Bryce?
mrscience ( ) posted Thu, 18 November 2004 at 4:59 PM ยท edited Fri, 24 January 2025 at 10:26 PM
When I put many trees in a scene Bryce does this. What's going on? Is this an actual glitch in Bryce? URL's: http://www.angelfire.com/vamp/renderprises/helpme1.jpg http://www.angelfire.com/vamp/renderprises/helpme2.jpg http://www.angelfire.com/vamp/renderprises/helpme3.jpg
Message edited on: 11/18/2004 17:01
dougocd ( ) posted Thu, 18 November 2004 at 5:26 PM
Yep, it's a glitch. Not sure if the 5.1 patch helps with this or not (I don't have the patch). This seems to happen when trees are too close together, or when there is a lot of haze. It's a pain in the arse, but I usually move the trees around until they become "whole" again.
haloedrain ( ) posted Thu, 18 November 2004 at 6:01 PM
You can fix it if you change each tree slightly in the tree lab so they're not exact duplicates of each other.
Aldaron ( ) posted Thu, 18 November 2004 at 6:49 PM
Yep what haloedrain said or instead of duplicating them make a new tree for each, either way works.
Claymor ( ) posted Thu, 18 November 2004 at 6:55 PM
It sill does it even with the 5.1 patch and as said, it seems to happen when duplicate trees are too close. Create a new tree for the trouble spot or spread 'me out.
mrscience ( ) posted Thu, 18 November 2004 at 8:01 PM
okay, I'll try the what you guys said. Thanks for the help; I appreciate it!
Quest ( ) posted Thu, 18 November 2004 at 8:32 PM
Mrscience, I believe this has to do with the fact that Bryce trees are metaball objects and react like this when put in close proximity to each other.
foleypro ( ) posted Thu, 18 November 2004 at 11:20 PM
To close and need to change...So yes everything said above... Note to all users... Save your Tree's as an OBP file then Most times this doesnt happen...Why I am not sure...At least on my machine it seems to stop...
Incarnadine ( ) posted Sat, 20 November 2004 at 10:17 AM
I did a series of tests on trees a while back and the thread should still be available here in the forum. The issue is that if you are using duplicated trees they interfer as the settings are identical. tweak one or two of the parameters in the treelab for each tree and this no longer happens. It is indeed a glitch.
Incarnadine ( ) posted Sat, 20 November 2004 at 10:32 AM
