Sun, Feb 2, 11:44 AM CST
Subject: Need a Little Help...And some Heavy Crits Welcomed...
foleypro ( ) posted Sun, 28 November 2004 at 12:47 AM · edited Sun, 28 July 2024 at 3:43 AM
This is a WIP... Ok Before I finish this Pic and upload a Final Render(We all Know Bryce and Render times)I wanted to gety some HONEST feedback on this Pic...Granted this is a Later evening Based scene... I feel I need to lighten it up some...You...
pogmahone ( ) posted Sun, 28 November 2004 at 1:03 AM
I kinda feel the other way round - I'd expect the background to be much darker, and the front of the dragon and witch to be much brighter, with the light from the fire falling off very sharply. I think that witch is in danger of getting a cold on her kidneys lol I'm trying to remember what the light is like at dusk. It can also look all bleached-out, with everything grey.
Claymor ( ) posted Sun, 28 November 2004 at 1:14 AM
I tend to agree with pog...my first thought before I read what you'd written was that the lighting made it feel a little "flat"...creating a little more contrast between the lights and darks could help there...especially on the woman...bright front, darker back. Based on the title...the scolding...it might be interesting to pull the camera in closer so the dragon more fills the screen and we can read the woman's expression.
tresamie ( ) posted Sun, 28 November 2004 at 2:35 AM
Maybe put the woman up on a rock or something to bring her in closer to the dragon...maybe put her on a low cliff with the fire on the floor, and give her a torch/staff for some light. Also the sky looks more like rain than evening...how about some last bit of sun or a touch of pink in the clouds. I really like this image a lot! I'm not sure it needs more light, but maybe just more contrast.
Fractals will always amaze me!
RodsArt ( ) posted Sun, 28 November 2004 at 2:42 AM · edited Sun, 28 November 2004 at 2:47 AM
I agree about the flat look, What's happening is the focus of the scene is in all 3 levels...fore,center and background, which is confusing the focus. Little items like the mushroom are also pulling the main focal point away from the middle of the scene.(move it to about 10-O-clock of the fire). Both flowers distract too, they could be off to the side, closer to the foreground & slightly blurred.
Not sure how much post work you're planning, but if the render times are slowing you down, you could build the scene in seperate layers by rendering masks, building it in an image editor using layers. Check out the lighting I used in :"Farie Dust". Even though you can see the sides, it doesn't pull from the main focus.
Check out hobbits gallery, there are some excellent examples of composition rules for depth perception, lighting & subject matter focal point.
Great Fantasy Scene so far.
Keep us updated.
ICM
Message edited on: 11/28/2004 02:47
___
Ockham's razor- It's that simple
Erlik ( ) posted Sun, 28 November 2004 at 2:59 AM
The problem with sky is not that it misses a pink streak, but that it's a darkened daylight sky. You know what I mean? Like you just lowered the diffusion. Then, the light from the fire is still too cold. It should be more orangey. Also, it's too uniform. Use a turbulence as the gel.
-- erlik
pogmahone ( ) posted Sun, 28 November 2004 at 3:04 AM
Use a turbulence as the gel. Great tip!
TheBryster ( ) posted Sun, 28 November 2004 at 8:19 AM
That sky might be one that's moonlit - you just can't see the moon. We get a lot of them around here. The moon's so bright you could read a newspaper - not that I read newspapers you understand...
foleypro ( ) posted Sun, 28 November 2004 at 11:27 AM
Here is what the scene started out as...A test for Lighting and such,I did reuse a scene and I moved things around asked some opinions and was told it was toooo Dark and redish,So I changed to the Pic above....
RodsArt ( ) posted Sun, 28 November 2004 at 11:45 AM
Whoa, I like this. The sheild & rock behind her are a bit out of place. I'd start here....Oh yeah, you did!
___
TheBryster ( ) posted Sun, 28 November 2004 at 11:50 AM
Well this is one way to roast nuts on the fire...;-)
pogmahone ( ) posted Sun, 28 November 2004 at 11:57 AM
lol - we're obviously the only ones with twisted minds, Bryster
foleypro ( ) posted Sun, 28 November 2004 at 2:00 PM
Excellent thing about all of this is...I have the Original scene all the way to three revisions...
Ang25 ( ) posted Sun, 28 November 2004 at 4:15 PM
I like the background and the colors of the trees in the second image you posted. I think if you cross the best of both you'll have a fantastic image!
Erlik ( ) posted Sun, 28 November 2004 at 5:13 PM
And I think that composition is better in the second one. The orange clouds are not good, cause they are lit too ... damn, what's the word ... not monotonously ... but you know what I mean. I hope. :-) firelight is still too cold.
-- erlik
brycetech ( ) posted Sun, 28 November 2004 at 8:13 PM
Ive seen this before havent I? lol suggestion? Put something in the foreground...anything :) and I think I like #2 better too. :)
shadowdragonlord ( ) posted Mon, 29 November 2004 at 1:24 AM
I think that i like the POV better in the second one, but since we're not working backwards... The dragon should be bigger. Unless you intend for it to be an adolescent, which the Millenium Dragon is not really a teenager. It would create a more dramatic sense of scale... Honestly, aside from what ICM said, I think the image would be more appealing if you just flipped it. Horizontally, you know? Mirror it, and take a look... It draws your eyes along it's elements in a much smoother way.
foleypro ( ) posted Mon, 29 November 2004 at 11:01 AM
Thanks guys...Because of the suggestions I have come up with this one...LOL
foleypro ( ) posted Mon, 29 November 2004 at 12:49 PM · edited Mon, 29 November 2004 at 12:51 PM
It will be called one of Two Names... 1.The Scolding... 2.The Finger.... Hmmmmmmmmm... NO Postwork on any of the Images...I just saved as Jpg....And the Name on the top one...
Message edited on: 11/29/2004 12:51
foleypro ( ) posted Mon, 29 November 2004 at 1:31 PM · edited Mon, 29 November 2004 at 1:36 PM
The Dragon and Kaleasha the Witch are set as One and Grow together into a Bonding that can only be Broken by Death,And since They will Live many Generations the Dragon and Her will Grow Bigger together Of course the Dragon Will Far Out Grow the Human,The will of Kaleasha is the only thing Keeping the Dragon in Check...She is just scolding Pyro for Eating a Farmers Goat that lives by the Castle...Lazy is as Lazy Be.... Kaleasha is a Character I have been working on for awhile now and since I just got The MilGirls I can now go from a Baby to and Adult with the Story...
Message edited on: 11/29/2004 13:36
shadowdragonlord ( ) posted Mon, 29 November 2004 at 3:58 PM
Yep, Kaleasha rules. Very cool... The latest render is a much better image, in my opinion.
RodsArt ( ) posted Mon, 29 November 2004 at 4:01 PM
Yeah!! Much more power in this rendition. Nice work!!
___
foleypro ( ) posted Mon, 29 November 2004 at 4:11 PM
Thanks
