Tue, Nov 26, 11:02 PM CST
Subject: Can't get normals creased on 3DS/OBJ import
dhenton1000 ( ) posted Thu, 02 December 2004 at 5:12 PM ยท edited Thu, 15 August 2024 at 8:59 AM
Okay. Time for the experts. I've got 3DS and OBJ models that I bring into poser, and the normals are not creased. Thats okay if you bring in a OBJ banana, but if its a sci-fi door, its a mess. Does anybody know how to get POSER to recognize creases? In Bryce/et al, theres a routine that recalculates normals based on a cutoff angle, anything like that in POSER? So far, I've looked for this functionality in Carrea 1, but when it exports, it doesn't seem to pass on crease information. Any help greatly appreciated!!
Little_Dragon ( ) posted Thu, 02 December 2004 at 5:22 PM
Poser calculates normals on-the-fly, so to speak. It ignores any normals already included in the mesh, so there's little point in leaving them in. If you want creases, you'll need to create a tiny bevel along those edges, or else split the vertices along those edges.
SamTherapy ( ) posted Thu, 02 December 2004 at 5:28 PM
If I understand you correctly, you mean objects brought into Poser look like a crumpled sheet. Easy enough to correct in UVMapper by selecting "Split Vertices". In UVMapper Pro, you can select the angle of split, too.
flyerx ( ) posted Fri, 03 December 2004 at 12:42 AM
Attached Link: http://user.txcyber.com/~sgalls/
You can try PoseRay. PoseRay can import both 3DS and OBJ and fix the creases.
Check the tutorial in the manual on how to use PoseRay to import creased models into Poser.
good luck,
FlyerX
flyerx ( ) posted Fri, 03 December 2004 at 12:52 AM
Here is an example of a 3DS model in Poser 4 with creases cleaned by PoseRay.
FlyerX
