Attached Link: http://www.renderocity.com
What I see on this image is wrong using of bump maps, you must use also the anti-alias for the rendering the maps are made for users that made a images with big format min 800x600 if you create a small image it will not working corect. If you still have problems with the body don't not use the bump map with 100% only with 50%, you are the first person that have problems with the maps. Wish you much succes with your rendering and if you have any problems just e-mail me to cathrin@worldonline.nl .The bump maps and the texture maps can be adjusted using the little slider bar under the little menu where you choose the name of the file. I think it just takes a little practice and the maps come out very nice. I liked this map particularly ...also fool around with the lighting and the other settings on the render material options
