Sun, Jan 26, 11:53 AM CST
Renderosity Forums / Fractals
Welcome to the Fractals Forum
Forum Moderators: Anim8dtoon, msansing
Fractals F.A.Q (Last Updated: 2025 Jan 21 7:59 pm)
Subject: Having trouble with the copy/paste function in UF ver 3.0.2...
AceHarddrive ( ) posted Fri, 10 December 2004 at 11:17 AM · edited Mon, 19 August 2024 at 7:51 AM
Trying to work my way through the Help files Tutorials, but I've run into a snag. I can't copy/paste parameters from the tutorial into UF. I click on the parameters (thinking it will copy onto the clipboard), but I guess nothing gets copied, because I can't paste from there. Can anyone help? ~Tim ^_-
aartika ( ) posted Fri, 10 December 2004 at 4:17 PM
Hi Tim,
I'm not sure where exactly you are in the tutorial, but I'm guessing it's at the point where you need to paste the julia seed in "Learning basic skills" >> "learning to use switch mode" >> "Synchronising the julia seed".
When you click on the blue higlighted parameters in the tutorial:
-0.2589852008
-0.1395348837
you will copy those parameters to your clipboard.
You then need to paste those parameters into your open fractal, by right-clicking on the blank field to the right of "Start value (Re):" on the formula tab of the Layer properties window, and choosing "Paste complex value" - see image.
if I have got the wrong end of the stick, please say so! Tina
aartika! fractal art by Tina Oloyede :  http://www.aartika.co.uk
AceHarddrive ( ) posted Fri, 10 December 2004 at 8:01 PM
No, we're on the same end of the stick, Tina! The problem seems to be that the parameters are not getting copied to the clipboard. I tried this with all of the parameters we are instructed to copy/paste in these tutorials. When I go to paste them into UF, the only option I see when I right-click is copy (paste is grayed out). Normally (as when copying parameters in the email listing) copy/paste works just as it should. Any ideas? ~Tim ^_-
sofie-filo ( ) posted Sat, 11 December 2004 at 12:50 AM
Hi Tim, Why do you use UF 3.02? Why not using UF 3.05. It's free to download that version. BTW about your question. Why not send a message to the UF list? Many of the UF list members can give you a correct and gratified answer. I know from the past you are an UF list member too! All the best, Jos Boogen.
AceHarddrive ( ) posted Sat, 11 December 2004 at 2:51 AM
Ooopsie! I had downloaded 3.0.5, but neglected to install it! Okay, I just installed it and tested it out...same problem. Thanks for the suggestion, Jos! I'll post to the list right now! ~Tim ^_-
