Thanks, I figured it out. Simply enter the Setup room, bring up the heierarchy window and drag all the props you want underneath a single prop. This will be the figures body. Then simply save it as pz3 file. Bring it into 3DSMax via the pro-pack plugin and there are all your textures with mangled map paths. This is exactly what I was looking for. The only thing better would have been if pro-pack actually got the pathing right. But that'll never happen. Thanks again, Enivob
Hi All, I have existing textured props that I want to use in Max. I am exporting them as OBJ files. When they come into max, all the pathing to maps is lost, even if I import the MTL file. I am using Poser 4 with Pro pack link to Max 3. I have noticed that if I import a figure using the propack, the scene materials at least have the names of the textures in them. My thought was if I could convert some of my complicated textured objects into figures, bring them into max via pro pack, I could extract then map names and paths from the pro pack material. Does anyone know how to convert props to figures? Thanks
