It's hackable, but doesn't always accept the same values that a pose file would, because it is not a pose file. It's only applicable to a single material, as well, and so far doesn't appear to be extensible beyond it. It's also even more a persnickity format than a pose file. I've been trying to write a custom material that adds in (but doesn't connect) several nodes at once and, well, it's pissing me the hell off and so I'm coming here and venting on poor unsuspecting folks. gah! Ok, sorry. The MT5 settings do, however, transfer over into pose settings. Camera's are a bit problematic, as they tend to try and attach to the camera when applied. but, well, that's some of what I've been learning off and on.
Lucifer's responding to a part I deleted from the post asking whether readScript could be used inside .CR2s to create legally distributable V3-based .CR2s. I'm following Rob Whisenant's documentation on this for further research.
A dialog box with all available materials checkable, so you could select every material zone you want, then apply the material with one click. Oh yeah, and a built in "Zero Everything" MAT file, too.
I'm not quite sure I understand the thread here, but reading it gave me an idea...You could write a phython script to enable you to select an MT5 file, and a bunch of materials in your figure, and it would apply that MT5 file to those materials. The code to do this is actually enbedded in the RealSkinShader, and it might be a neat tool to have. Would get around the complete absense of any phython methods to modify the mat room nodes.
Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
Mmmmmm, well I'll put it on the growing list of things to do. You could either specify a mt5 or pz2 as the source, and select the materials to apply to. In the case of the mt5, it would be replicated across all the materials. Will look into it in the new year if I get a moment.
Creator
of OctaneRender
for Poser
Blog
Facebook
Not trying to start a flamewar about whether Poser 4 users should upgrade, just asking a practical question from a Poser 5 user viewpoint.
face_off's complex skin shader is something I've saved to my Materials (along with its references to a specific head texture); if it's hackable I'd rewrite it to automatically apply it to all appropriate head materials and do the same for the body texture/materials.
Is it habit/custom, or is there a better reason?
Message edited on: 12/22/2004 14:42
