Tue, Nov 26, 12:48 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
Subject: Pixelation in render problem
LindaB ( ) posted Wed, 22 December 2004 at 1:26 PM ยท edited Wed, 13 November 2024 at 10:59 AM
I completed a render using Poser 5, in it V3 is wearing 'The Dress' Headpiece and Hood, with the Nuits Blanches - Chapeaux texture. As you can see from the image I provided - V3 rendered fine - but the headdress and hood are all pixelated. I tried both the Firefly renderer and the P4 renderer, and both renders were pixelated. Is it just that the Nuits Blanches texture maps are too small for close-up renders? Or have I done something wrong? Any suggestions? thanks, Linda B
richardson ( ) posted Wed, 22 December 2004 at 2:06 PM
I don't really know the exact fix here, but you can easily cut the texture scale in half (U&V scale) and add quite a bit of bump to break it up. The lightest taupe grey would help bring it into the tonal range, too imho
PapaBlueMarlin ( ) posted Wed, 22 December 2004 at 11:28 PM
Did you make sure to antialias your P4 render? I would send an IM to the author of the set explaining your problem and asking for help.
greetinx ( ) posted Thu, 23 December 2004 at 3:33 AM
Have you unchecked smooth polygons in the render options ? I have this problem sometimes with certain lighting and camera angles.
LindaB ( ) posted Thu, 23 December 2004 at 12:54 PM
Thanks for your help. I think the problem had something to do with my settings for the bump in P5. Once I set the bump back to the default setting, the pixelation was gone. The bump looked better with the settings I had, but I had to change them back to default to get rid of the pixelation. Thanks to all who took time to reply. Linda B
