Tue, Nov 19, 12:46 PM CST
Subject: Python and collision
xantor ( ) posted Mon, 27 December 2004 at 10:10 AM · edited Tue, 19 November 2024 at 12:43 PM
With poser 5 would it not be possible to make a python script to make figures or (more likely) props react with each other like pool balls hitting each other using collision detection?
ockham ( ) posted Mon, 27 December 2004 at 10:17 AM
It's certainly possible in either version. P5 doesn't give Python any connection to its coll-det, so it's really no different in this regard. Problem is, the calculations take SO LONG that it's not necessarily worth automating. For relatively simple objects, it's not so bad. But for Vicky-size meshes, you run into huge numbers of calcs.
My python page
My ShareCG freebies
ockham ( ) posted Mon, 27 December 2004 at 10:25 AM
And a broader problem with doing "honest" physics in the digital world is that our props and figures have no representation of mass and friction. They're all equally weightless and smooth, so such measures as momentum or drag have to be dummied from speed alone, or estimated from the volume of things.
My python page
My ShareCG freebies
maxxxmodelz ( ) posted Mon, 27 December 2004 at 10:50 AM
"And a broader problem with doing "honest" physics in the digital world is that our props and figures have no representation of mass and friction" In some applications you can assign mass and friction to objects to approximate physics calculations such as velocity, momentum, etc. right down to the vertex level. You can actually "paint" different weights on different vertices or polys to react with gravity. However, this is something not yet possible in poser. :-(
xantor ( ) posted Mon, 27 December 2004 at 11:05 AM
You could use the standard breakout type bouncing ball way of animating the collisions the collisions and movements wouldn`t have to be too exact. I knew it would be more difficult for figures that was why I said it would be more likely for props.
ockham ( ) posted Mon, 27 December 2004 at 11:11 AM
Well, you got me started on this again. I'll use volume as proxy for mass, and see how it goes.
My python page
My ShareCG freebies
xantor ( ) posted Mon, 27 December 2004 at 10:15 PM
3dstudio max version 6 has some kind of collision detection (I forget the name) but they have an animation of it working where a figure hits a wall and the wall is knocked down, something similar with python would be good. It wouldn`t have to be too complicated, the wall parts that break up could be preplanned so that there are not too many calculations involved.
ockham ( ) posted Mon, 27 December 2004 at 10:30 PM
Here's step 1 in the process: elastic billiard balls with the cueball bigger. Next step is to account for squishiness and the other mass possibilities. After that, a more precise form of surface detection. (At the moment this just uses the radius, which is OK for nearly spherical things but not OK for figures.) This GIF shows the PZ3 before applying the script. The big ball passes through the little one in true Poser ectoplasmic style.
My python page
My ShareCG freebies
ockham ( ) posted Mon, 27 December 2004 at 10:31 PM
And this GIF shows the result after applying the script.
My python page
My ShareCG freebies
xantor ( ) posted Mon, 27 December 2004 at 10:38 PM
That is a good start, I would`nt bother too much about gravity and friction etc at least to start with and just make the script work properly. Other effects could be added later.
ockham ( ) posted Mon, 27 December 2004 at 10:44 PM
I think the hardest thing, at least on the thinking level, will be to determine what kind of thing the target does. Slide, roll, fall over, hold steady, break through, squish? This will just have to be a user choice, because the physical information is unavailable in the Poser world, and would be WAY too complicated even if it were available!
My python page
My ShareCG freebies
