Hi camelot77,
You might try this ...
Hide everything except the unrendered object.
"Paste onto Background."
Hide the unrendered object.
Render (everything else) over Background image.
Or, do it in the reverse order if required for the unrendered object to be in the foreground.
Note - You don't want to move the camera between shots, obviously. ;=]
Holiday cheers,
from dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
"What are you doing that makes an object look better UN-rendered?" That was why I asked to see the rendered and unrendered versions of the scene. It could be the problem with rounded polygons when you have to do the spit vertices thing with uvmapper to make them look right. They sometimes look worse when rendered.
is it possible to make an object not get rendered in a scene but still be visible? I have an object in a scene that looks better unrendered.
