Fri, Jan 24, 7:55 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Carrara Free Stuff here.
Subject: C4 Update Question
chuckerii ( ) posted Mon, 27 December 2004 at 5:21 AM · edited Fri, 24 January 2025 at 7:54 PM
I am currently rendering a large animation via a Batch render. I would like to take advantage of the new update (4.0.1) which boasts a slow rendering fix. If I update to 4.0.1, will it wipe out my current Batch render? Chuck
falconperigot ( ) posted Mon, 27 December 2004 at 6:58 AM
I hadn't updated so I did a quick test, setting up a short animation, paused the batch render and then installed the update. My render was still there afterwards and resumed ok. I won't be held responsible if it doesn't work for you :-) but it did work for me. I don't know where details are saved for batch renders but you might make a copy of your Preferences file before updating as a precaution. Mark
chuckerii ( ) posted Mon, 27 December 2004 at 7:20 AM
Thank you Mark! I am rendering in sequenced frames, so if I do lose the batch, I will still have the rendered frames, so no worry. ;-) I'll be anxious to see just how much improved the speed actually is. Thanks again for your help! Chuck
brainmuffin ( ) posted Tue, 28 December 2004 at 1:51 PM
I have a silly question: How does Batch Rendering work? I've never used it before.....
falconperigot ( ) posted Wed, 29 December 2004 at 11:21 AM
Batch Rendering is very useful. You don't need to load a file into C, simply switch to the Render room and select the Batch Queue button. Press Add to add a file to the list; you can add only one file if you want, alter render settings if you wish and then press Launch. You can now Pause the render at any time, close C (even switch off your computer) and resume later. This is particularly useful if you are rendering a large scene file or a long animation. Added to which, in my experience Batch rendering is more stable than straight rendering. Mark
brainmuffin ( ) posted Wed, 29 December 2004 at 11:32 AM
Kewl......
sailor_ed ( ) posted Thu, 30 December 2004 at 9:07 AM
I have had some problems with this feature in C3 with discontinuities in the image when restarting renders. Has anyone else had these problems? I have not tested it in C4.
