Phillip Drawbridge
Website
Facebook
Pardon me if I'm being stupid, but couldn't you get the exact same effect by making the celtic pic gold and white and mapping it to a single booleaned cylinder, then messing with the reflectivity etc. to make it look like metal? No 2nd booleaned cylinder, no transparency map needed?
Hey, no need to back up, you've got your object. :^) I always have 20/20 hindsight, LOL. Just thinking about other ways to do it. It would be cool if there was some way to extrude the Celtic pattern so the gold looked raised.
Yeah, I wondered about that too. bump mapping just doesn't do it. Or better yet, inset. I've just tried your method and it works fine (if my bitmap was slightly better). Saves one cylinder. I can't quite get the gold colour right. But that's just a photoshop issue.
Phillip Drawbridge
Website
Facebook
You could get the alt color picker for the gold color you're using in Bryce in the DTE to get the numerical values, then type them into Photoshop to get the exact same color. I think. :^)
We take our name etching bump map with Quest and 18K written backwards from right to left. Figure 1.
We apply it to the inner ring surface and it shows up as in figure 2, backwards as it was written on the map. To see it written correctly we must rotate the ring object so that the words show up in the viewable area here marked in blue. Figure 2.
We rotate our ring object. Figure 3.
The same bump map but now rotated so that the words can be seen and they appear as normal reading from left to right. Figure 4.
Ohhhh let me think.... Um if there were a mirror behind that ring would the words would be seen on its outside as well? I guess that was one thing that I didn't think about and would explain the rotating, lol. So if thats the case then you'd have to be careful in scenes not to have something reflective behind the object. :-D Thanks!
Message edited on: 01/09/2005 08:19
Phillip Drawbridge
Website
Facebook
