Mon, Jan 20, 9:14 PM CST
Subject: What the Frig am I doing wrong!!!???
bandolin ( ) posted Tue, 18 January 2005 at 1:33 PM · edited Wed, 08 January 2025 at 8:55 AM
Here's the texture (just as a test mind you, not the final)
<strong>bandolin</strong><br />
[Former 3DS Max forum coordinator]<br />
<br />
<a href="http://www.renderosity.com/homepage.php">Homepage</a> ||
<a href="http://www.renderosity.com/mod/sitemail/">SiteMail</a> ||
<a href="http://excalibur.renderosity.com/mod/gallery/browse.php?user_id=70375">
Gallery</a> || <a href="http://www.renderosity.com/mod/freestuff/index.php?username=bandolin">
Freestuff</a>
<p><em>Caution: just a hobbyist</em></p>
bandolin ( ) posted Tue, 18 January 2005 at 1:34 PM
In Bryce...
<br />
Freestuff</a>
bandolin ( ) posted Tue, 18 January 2005 at 1:35 PM
These are the settings...
<br />
Freestuff</a>
bandolin ( ) posted Tue, 18 January 2005 at 1:36 PM
This is what I get. Where's my texture?
<br />
Freestuff</a>
Ang25 ( ) posted Tue, 18 January 2005 at 1:43 PM
No clue, but for the heck of it try putting the dot from the first column back to next to the diffusion. Just a guess.
pogmahone ( ) posted Tue, 18 January 2005 at 1:47 PM
Have you tried removing the ambient, diffusion and metallicity dots from where you have them at the moment?
Jaymonjay ( ) posted Tue, 18 January 2005 at 1:49 PM
Try 'Object Cubic' mapping, rather than 'Parametric'.
pogmahone ( ) posted Tue, 18 January 2005 at 1:54 PM · edited Tue, 18 January 2005 at 1:59 PM
PS, forgot to post the image....and, like Jaymonjay says, Object Cubic would be better than Parametric
Message edited on: 01/18/2005 13:59
bandolin ( ) posted Tue, 18 January 2005 at 2:05 PM
Yup, Object Cubic did the trick. I don't know why it would make a difference, but apparently it does. Thanks Jay, Pog.
<br />
Freestuff</a>
dan whiteside ( ) posted Tue, 18 January 2005 at 2:10 PM · edited Tue, 18 January 2005 at 2:12 PM
could be that the model has no UV mapping, which is what the parametric mode needs for all imported meshs. Otherwise the import gets painted a solid color, I think the top left pixel color in the image file.
Message edited on: 01/18/2005 14:12
Jaymonjay ( ) posted Tue, 18 January 2005 at 2:29 PM
Yep, dan whiteside is correct. Glad you figured it out, Bandolin. :)
lordstormdragon ( ) posted Tue, 18 January 2005 at 6:32 PM
Also, having the dots in the valu section over-rides the actual level numbers. So, with the dot in Difffusion, the number value means nothing, and is based off of the Alpha.
Claymor ( ) posted Wed, 19 January 2005 at 11:13 PM
I have found that parametric NEVER works for stuff modeled in Wings/ I always go object cubic
lordstormdragon ( ) posted Thu, 20 January 2005 at 3:29 AM
If parametric doesn't work, then the UV maps aren't right... But, in this case, there is no UV mapping. When you move on to multiple textures within a single model, you will use UV mapping, but for now, looks like it's all safe?
