I like the planes a lot, and like the way you can't really tell the shape of the robots except from the shadow. The ground is a kinda boringly flat, same goes for the texture on the ground. I've just noticed that the robots are coming out of the crates, it might be interesting to have more of them moving out of the crates, rather than scattered around the picture. There are a few objects and shadows that are unexplained.
Agree with pog. Terrain could use some interest. What's with the flying ramp in the upper left hand corner? For that matter the crate in the upper right has something funky going on. I think that's what pog's mentioning about unexplained objects. Keep at it.
<strong>bandolin</strong><br />
[Former 3DS Max forum coordinator]<br />
<br />
<a href="http://www.renderosity.com/homepage.php">Homepage</a> ||
<a href="http://www.renderosity.com/mod/sitemail/">SiteMail</a> ||
<a href="http://excalibur.renderosity.com/mod/gallery/browse.php?user_id=70375">
Gallery</a> || <a href="http://www.renderosity.com/mod/freestuff/index.php?username=bandolin">
Freestuff</a>
<p><em>Caution: just a hobbyist</em></p>
hi people... Well the odd flying thing in the upper left hand corner is a landing craff... (How the boxes get transported around) and i'm working on the Terrain but having a few problems with it Thanks from darkness
You imagination is your only limitation.
Check out Dark Design for freebies for your own artwork.
you can start with the Planes and Terrains material section, stock Bryce stuff. One cheat I use is to create a terrain, duplicate it, and rotate the duplicate by x degrees (you fix the number). Same for trees, etc. Fast, and occasionally effective. You can change the textures on the trees, one vs. another, or use the Tree lab to change types, just to give it some variety. Just a thought.
hey, that terrain is pretty damn cool! If you increased the resolution of it (grid over on far left hand side of terrain editor) to massive resolution, then increased the size of the mesh hugely once back in the work area, and flattened the mesh down quite a bit on the Y axis.....it'd look really great.
I wish I had the amount of time to spend in Bryce that you do. I'm envious. Just a thought, the mech's legs look backward to me. Usually, Bipeds have backward knees.
<br />
Freestuff</a>
![file_172652.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_172652.jpg)
In the beginning no one new what would happen. But we always new that a lot would cast away from this life and yet in the chaos to come. no one would see the light of hope to fill the sand fulled sky. _____________________________________________________________ Created by using bryce 5 and wings3D... Comments Plz thanks from darknessYou imagination is your only limitation.
Sitemail - Dark Design
