Sun, Feb 2, 12:32 AM CST
Bryce F.A.Q (Last Updated: 2025 Feb 02 12:16 am)
Subject: Regular v Super rendering quality - worth it?
arcady ( ) posted Fri, 21 January 2005 at 4:58 PM · edited Fri, 24 January 2025 at 12:17 AM
Is there a worthwile difference between Regular and Super on rendering quality?
Truth has no value without backing by unfounded belief.
Renderosity Gallery
Rayraz ( ) posted Fri, 21 January 2005 at 5:08 PM
only on images that require high AA settings :)
(_/)
lordstormdragon ( ) posted Fri, 21 January 2005 at 5:22 PM
Aye, Higher AA samples always produce a more accurate image. If you are rendering small, such as to screen size, then you may not notice. But the biggest difference you'll see on small renders is when using photo-textures. These are always cleaner and less grainy when using higher AA settings. Do a Search here in the forums, Agent Smith has some excellent screen shots of this process in action.
Aldaron ( ) posted Fri, 21 January 2005 at 7:03 PM
Take a cube or square 2d face and stretch it to a long rectangle. Apply a plaid pattern to it then have one end near the camera and the other end going into the distance away from the camera. You'll see the difference. Otherwise you will only see a difference in fine patterns like that, if you don't have anything like that or fine wire meshes, etc...don't bother with it.
FWTempest ( ) posted Fri, 21 January 2005 at 8:30 PM · edited Fri, 21 January 2005 at 8:32 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=826647
check out this thread... I knew it was around here, somewhere... I just can't believe it was that long ago... I've been here too long... ;o)
Message edited on: 01/21/2005 20:32
erosiaart ( ) posted Fri, 21 January 2005 at 8:54 PM
do it ONLY if you selling an image..and want a print..or even if you selling a tiff file... BUT..ONLY if you think there will be a difference..
Pedrith ( ) posted Fri, 21 January 2005 at 9:39 PM
Also if you are rendering an animation, super quality will reduce the amount of flicker you get, but it will take a long time. Cheers. Pedrith :)
AgentSmith ( ) posted Sat, 22 January 2005 at 6:14 AM
Whew...blast from the past, FWTempest. ;o) AgentSmith
