Bryce F.A.Q (Last Updated: 2025 Feb 02 12:16 am)
Aye, Higher AA samples always produce a more accurate image. If you are rendering small, such as to screen size, then you may not notice. But the biggest difference you'll see on small renders is when using photo-textures. These are always cleaner and less grainy when using higher AA settings. Do a Search here in the forums, Agent Smith has some excellent screen shots of this process in action.
Take a cube or square 2d face and stretch it to a long rectangle. Apply a plaid pattern to it then have one end near the camera and the other end going into the distance away from the camera. You'll see the difference. Otherwise you will only see a difference in fine patterns like that, if you don't have anything like that or fine wire meshes, etc...don't bother with it.
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=826647
check out this thread... I knew it was around here, somewhere... I just can't believe it was that long ago... I've been here too long... ;o)Message edited on: 01/21/2005 20:32
Whew...blast from the past, FWTempest. ;o) AgentSmith
Contact Me | Gallery |
Freestuff | IMDB
Credits | Personal
Site
"I want to be what I was
when I wanted to be what I am now"
Is there a worthwile difference between Regular and Super on rendering quality?
Truth has no value without backing by unfounded belief.
Renderosity Gallery
