Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 1:30 pm)
Glad I saw this post! I just bought the lights last night, so at least I know what will happen when I use them!
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
System Ram: 8GB
These are excellent lights and I use them all the time. Most of the time they seem to work just fine, pokeydots, but every once in awhile I have a problem with them and using the python script for deleting the lights just doesn't seem to work. I think you'll really like them though even with that teensy little problem :) Highly recommended.
Ohhhh, I'm not complaining :) I'm just glad I know this so I don't pull my hair out trying to figure out what was wrong. ;o)
System Ram: 8GB
Thanks for letting us know ;o)
System Ram: 8GB
I've had a problem only with the last lights in the set that the "delete lights" script won't work with. But to be fair I also have one light set that came with a hair prop (!!! Real) that won't respond to the script either. Both of these have a zillion lights, so perhaps it's the script pooping out when it reaches a certain number of lights to deal with (and not the lights at fault). Ockham would know better about this. SWAMP
Thank you for bringing this up.
Ive been trying to figure out where the problem is but since I have no knowledge on Python scripting, it is very hard to come to any actual conclusions.
The only way was to seek a true experts advise, so Ive contacted Ockham asking for some help and he courteously agreed to look into the light set and see if he can spot anything.
Hope well be able to provide a solution soon :o)
When you isolate which light or lights won't delete, check the shadow map size against the set default limits for the light(s). I had a case where a light wouldn't delete (not danae's set) and the shadow map was set at 1200, but the maximum in the default setting was 1000. Changed the size downwards and it became deletable (hope that's a real word).
i just checked one set...and 1 light in there..the map size is 1200 and the max res is 1024 in the render options. Is this what you're talking about? the only prob, if this is what you're talking about, some of these sets have gobloads of lights. it would take a week to change all the maps size entries...or i suppose it would be easier to increase the max texture size? Now, what is that for actually? I always use textures larger than 1024 resolution...skin textures are 3000 and up...a lot of the cyxlorama type textures are 1600x1200...so i must be looking at the wrong numbers
Humankind has not
woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound
together.
All things connect......Chief Seattle,
1854
I highly recommend ockham's Light Panel, too. It's absolutely essential for dealing with lots of lights and even on small sets it makes things a whole hell of a lot easier.
Just for an update, I've been talking with Danae via IM. Think we've found the problem, and it's solvable. More later......
My python page
My ShareCG freebies
Thanks ockham and Danae! ;o)
System Ram: 8GB
Dave-So wrote "i just checked one set...and 1 light in there..the map size is 1200 and the max res is 1024 in the render options. Is this what you're talking about?"
No. If you select one light using the 'parts' menu at the bottom of the screen, the Parameters tab for that light shows a 'Map Size' entry in P5 (Shadow Map in P4). If you click the dial, it gives you the Min/Max settings for that specific light. I spotted it when exporting a PZ3 out of P4 and importing into P5. One light appeared dead-centre set at 100% pure white light, and it couldn't be selected or deleted. This may be the 'ghost light' effect referred to by Robo2010 above. Anyway, working back, I found that the light involved had a shadow map set larger than its maximum limit. And we all know how P5 gets its knickers in a twist over stuff like that. Though I'm not sure if that's the problem ockham and danae have found. But if danae created the lights in P4, then it could be a factor. Ah. danae can type quicker than I can .. cross-post.
Message edited on: 01/23/2005 04:53
ah...I see what you mean now with the map size, etc. This is great that a fix is coming :) thanks danae and ockham
Humankind has not
together.
1854
Incidentally, I looked first at Moochie's map size, because that does seem like a good candidate for this sort of problem. Tried changing the high numbers in the file back to 256, but that wasn't it.
My python page
My ShareCG freebies
I've been using this light set since it first came out, but have been having a problem deleting them using the python script. Some of the lights will delete, then it stops... I've been able to finally get them to delete by some technique that is unrepeatable...using the script multiple times, rendering, adding new lights, etc etc..some times it deletes others not. Any idea as to how to delete these?
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
