Did you just dupe the tree? sometimes Bryce doesn't like duplicated trees, but it's alright if each tree is a new tree....and some images use a 2D plane with trees on them for the mid to background trees. The more trees you use the more you will run into this problem....=(
Bryce Forum Coordinator....
Zhann that was a new model. I had the same problem when i duped a tree so i removed it then used another model. I was hoping to use tree models close to the camera because all up if i did things correct i wouldn't have more than 10-15 trees in the image. Fuzzy i did like you suggested and i still had the bottom part of the tree missing :( Looks like trees don't like me so i'll try working on a boring barren land scene.
I have opinions of my own -- strong
opinions -- but I don't always agree with them.
Can you do a screengrab of the tree trunk texture for us? edit - Oh wait up, don't worry, looked more closely at the foreground tree, and it isn't just a cut off trunk - looks like a bit has been cut out (there's a bit of the side trunk going below the cutoff) so its not a texture thing.
Message edited on: 02/03/2005 01:14
Digital
WasteLanD
CD- I did a research thread on this a while back. When identical (i.e. duplicate) trees overlap or are too close visually (at any depth into the scene) this will occur. Select the conflicting trees one at a time and alter a setting slightly (I usually use the random by one or two points) and it should work. If you still have problems, send me a copy of your file so I can see better what is happening. Richard
I have opinions of my own -- strong opinions -- but I don't always agree with them.
