Mon, Feb 3, 12:19 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Subject: mimic help?
Marque ( ) posted Fri, 05 January 2001 at 9:26 PM · edited Sun, 02 February 2025 at 11:41 PM
Any place to get some help with mimic? Marque
JeffH ( ) posted Fri, 05 January 2001 at 10:24 PM
I only tried out their public beta, but maybe I can help. What's the problem? I do know that in oder to use a figure with Mimic, the figure must have the same phenome morphs that the P3/P4 male and female figure have. I don't think the Millenium models will work with Mimic, nor will any of the animals in Poser4. -JH.
Marque ( ) posted Fri, 05 January 2001 at 11:01 PM
The vickie model will work if you fix the spelling in the cr2. I need help with the part after you apply the mimic file. I need to be able to have the model say a sentence, then raise her arm, then say another sentence. At this point if I put in a keyframe and raise her arm, her arm starts raising at the beginning of the animation, instead of waiting. Any ideas? I went to the poser manual and the poser handbook to see if I could get rid of the keyframes for that part, but I can't seem to get it. Thanks for getting back to me! 8^) Marque
Greeg72 ( ) posted Fri, 05 January 2001 at 11:02 PM
Can someone tell me where I might be able to get mimic? Is there a demo version, is it free, if not, how much is it? A site would help. Greeg72
Marque ( ) posted Fri, 05 January 2001 at 11:06 PM
There is a demo at www.lipsinc.com If you have poser be sure to get the mimic program the others won't work for you. 8^) Marque
JeffH ( ) posted Fri, 05 January 2001 at 11:12 PM
Marque, This is an animation and keyframing issue, not related to Mimic; it has to do with the various types of interpolation. LecBlue used to have a great page explaining all this, but it's a dead link now. The PoseAmation mailing list would be perfect for questions like this, it's moderated by a former Disney animator who uses Poser in his work. PoseAmation@egroups.com You can also ask around at the PFO, I remember Dave_L had a pretty good understanding of these concepts too. -JH.
Marque ( ) posted Sat, 06 January 2001 at 1:26 AM
Thanks, I'll head over there....just needed some ideas on where to look. 8^) Marque
wyrwulf ( ) posted Sat, 06 January 2001 at 4:55 AM
Attached Link: http://www.lecblue.com/
LecBlue is now at http://www.lecblue.com/ This has been a message from the Linkmaster General
JeffH ( ) posted Sat, 06 January 2001 at 11:45 AM
Well, that's good to know ;-)
TRAVISB ( ) posted Sat, 06 January 2001 at 7:31 PM
I HAVE MIMIC SOME TIMES IT WORKS GREAT AND OTHER TIMES I DONT KNOW WHAT THE HELL GOES WRONG ?WHAT FPS AND COMPRESSION DO YOU USE I FIND THAT 20 FPS WORKS BETTER THAN THE HIGHER SETTING ANYONE NOW WHY. I USE CINPARK CODEK BY RADIUS WITH 1 FOR MY KEYRATE
JanP ( ) posted Sat, 06 January 2001 at 8:34 PM
The reason why the arm raises from the beginning of the animation...... What you did point A was your first pose then you went to where ever point b was going to be and you set that keyframe Therefor right after passing point A the program thinks its supposed to raise the arm until it reaches point B your setup SHOULD be done this way. Set Keyframe A(Point A) Decide where you want to place your actual keyframe(Point C) where you make the object move. Before you set that keyframe go how ever many frames backwards you want and set another keyframe(Pont B) THis keyframe should be identical to your first one (Point A) The farther apart the two keyframes B and C are the longer the duration it takes to pose from POint A to Point C. In otherwords if Point B is too close to Point C then the object will move fast. I find that you can solve the imic issue two ways. One apply the mimic pose before animating any other part of that figure. Or, two. Uncheck "Use inverse Kinetics for all arms and legs, And so, stranglely enough Poser Dorks head does not twist into a pretzel. JanP
Marque ( ) posted Sat, 06 January 2001 at 8:42 PM
Thanks! I will try that, and I will let you know how it comes out. I won't be able to do it until later though. I appreciate the response to this question as I plan to use a lot of mimic stuff in the future and I need to get a handle on it. Thanks everyone and especially Jan. Marque
