Mon, Nov 25, 6:35 PM CST
Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
Subject: Poser 5 Dynamic Hair
Llyr ( ) posted Wed, 09 February 2005 at 3:18 AM · edited Mon, 25 November 2024 at 4:25 PM
Has anyone had any luck with getting Vue to render Poser 5 Hair without making it look like yarn? (Noisy/Crunchy) No matter what I do I get the "Yarny" effect such as the attached picture. Both the same file rendered using the final setting in Vue, and just normal firefly in Poser. The color issue is another matter, the I can work around that.
Umm the URL is:
http://home.earthlink.net/~rlecraig/poserstuff/PrincessPoserVue.jpg
Message edited on: 02/09/2005 03:20
Message edited on: 02/09/2005 03:21
thomllama ( ) posted Wed, 09 February 2005 at 3:27 PM
got the latest update? (Vue 5) that is supposed to fix a lot of the troubles with Dy hair...
Hexagon, Carrara, Sculptris, and recently Sketchup.
Llyr ( ) posted Wed, 09 February 2005 at 3:47 PM
Yep, the latest beta 5.05. That's what I used to render that.
thomllama ( ) posted Wed, 09 February 2005 at 3:48 PM
not getting an image.. says there are errors
Llyr ( ) posted Wed, 09 February 2005 at 4:25 PM
D'oh, I just figured out that I need to upload the picture HERE for it to show up, I'm used to lnking offsite.
kirwyn ( ) posted Wed, 09 February 2005 at 8:17 PM
I have the same problem Llyr. Vue 4 rendered Poser 5 dynamic hair even better than Poser 5 did. I wish they would address this problem in Vue 5.
Llyr ( ) posted Wed, 09 February 2005 at 8:27 PM
Well actually I had the same problem in Vue d'Esprit 4, no change at all in fact between them (with regfard to the hair).
kirwyn ( ) posted Wed, 09 February 2005 at 9:37 PM
Here's what I get. Both rendered broadcast. Vue 4 is smoother and less grainy than Vue 5.
Llyr ( ) posted Wed, 09 February 2005 at 10:37 PM
Here's the actual scene I made in Vue 4 d'Esprit (I think I used custom settings)
Llyr ( ) posted Wed, 09 February 2005 at 10:39 PM
And cropped to her face and hair close up (full res as I rendered it), note the yarn effect
Paula Sanders ( ) posted Wed, 09 February 2005 at 10:40 PM
Attached Link: http://www.perpetualvisions.com/articles-and-graphics/v5p5-tutorial-hair.htm
I wrote a tutorial on how to work with dynamic hair in Vue 5. It is possible to get good texture and color. I have attached a shot of a render I did in Vue 5 of an imported poser 5 person.
Hope this helps.
Paula
squid69 ( ) posted Thu, 10 February 2005 at 2:43 AM
regarding the top-most picture, the headpiece looks WAY better in Vue than Poser (or did you do that on purpose and I'm just stupid =)
Llyr ( ) posted Thu, 10 February 2005 at 3:16 AM
Actually I think Vue renders everything better than poser...... except the hair (I'm not sure why poser put that dark area at the hairline), Poser makes it look silky, smooth and fine, while Vue makes each strand thicker and puts hash marks in them as if each strand was a braid. Not the effect I want for that hair. btw I had found that tutorial before, but forgot about the shadows, I tried that as well as increasing the anti aliasing settings and got some improvement, but still find the strands thicker and with the hash marks to some extent.
Llyr ( ) posted Thu, 10 February 2005 at 3:22 AM
Here it is with the shadows recieve and cast turned off, and anti alias increased, the hair is quite a bit finer and smoother I must admit, I also changed the color to a very dark brown to achieve this shade of blonde.
