Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
Yeah ... it is a frustrating thing ... What you can also do, which is what I normally do, is to take what you really need to use and do those parts ... anything else you can probably do in photoshop or something. Typically I would do the glow there with a little touch up ... I migt do the skull and arm and sword and a few other bits aligned rigt to make sure I know what I would do in Photosop. Not sure what else but good luck
The thing is it never will or can line up. The only way it would work is if you left a equal space on all sides of the center character. But then he would be levitating inside the green guy. But since the feet of the shell and the base guy have to be even with the floor. The perspective get all messed up. I.E. the outer characters legs are longer as well a wider and deeper. The easiest way to do what you need is to not sweat the exact proportions of the outer shape. Do not scale the outer guy exactly the same in all directions. Of course since the pose has multiple items living in different planes this gets tricky. Since the outer shell does not have to be perfect and seamless. I suggest you ungroup the outer shell. And build it onto the central character peice by peice. Resize each leg, arm, sword etc. Speerately over the central character. Tis could take a to of time but it will work where working the entire outer shell as one object can not work.
The shell doesn't necessarily have to end at the bottom of his feet... The duplicate and enlarge would work, but when you position him, make sure to always place the "solid" feet on the ground. It is a magic glow after all. And you could use an "atmosphere" type material (like for planets) and color it green. Just my 2 cents.
Thanx guys for your help as it turns out I figured it out for myself (which seems to be happening a lot lately). Pnevai is correct it never would or could line up like that for exactly those reasons and the funny thing is I ended up doing exacly what pnevai suggested even before I read the comment. OoooOooOOo Creeepy. The new pic should be up soon.
