Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 21 3:32 pm)
Thanks for the tip, but I tried that. It doesn't crash, it just stops calculating. The cloth will run up to the frame where it stopped calculating. I think it does have something to do with the complexity of the mesh -- I tried making a simpler mesh and it ran fine. I guess I'll just have to scale back my ambitions!
Hey, I finally got a Dual 2GHz Mac G5, so I can actually use dynamic cloth now. The clothing that comes with Poser seems to work fine, but I was trying to make some of my own and I ran into problems. Everything goes fine until I calculate the simulation -- it calculates the draping and then starts the calculation. However, it only calculates the first few frames (about to frame 11) and then it just ends the calculation. I have set the calculation for the entire length of the animation, so that's not the problem. Like I said, it will calculate the entire animation with the premade items. If anyone knows why this is happening, I'd like to know -- also, if you have any tips or things I should watch out for, that would be great as well. Thanks!
