Sun, Feb 9, 7:41 AM CST
Subject: is there a tut for making glass in poser?
anxcon ( ) posted Tue, 22 February 2005 at 7:36 PM ยท edited Sun, 09 February 2025 at 7:40 AM
i need a tutorial for making glass in poser and cant find its glass for a window, but has a front and back poly so it shows "depth" in the glass and viewable from both sides thanks
Tunesy ( ) posted Tue, 22 February 2005 at 9:36 PM
Just white in diffuse and 0.9 in transparency can do ok for a window. You can mess with refraction, highlight, etc if you like. Here's a quick window with only transparency changed to 0.9 (both sides of the window) and the rest default. Pay no attention to the hapless guy falling behind the window.
Tunesy ( ) posted Tue, 22 February 2005 at 9:46 PM ยท edited Tue, 22 February 2005 at 9:46 PM
...oops. I told ya wrong. That's not quite white. It's the first shade of gray to the right of white in the windows color picker, so almost white. That's what I use more out of habit than anything else.
Message edited on: 02/22/2005 21:46
dialyn ( ) posted Tue, 22 February 2005 at 11:06 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12413&Form.ShowMessage=2131713
Take a look at what Catherine is doing...!
anxcon ( ) posted Tue, 22 February 2005 at 11:06 PM
id use a bit towards a light blue/green but still cant get the glass to look quite right need to know about refraction n stuff :)
Tunesy ( ) posted Tue, 22 February 2005 at 11:18 PM
...don't forget that most of the time the viewer won't actually have a perspective to perceive refraction through a window since you won't usually be seeing part of the object through the window and part of it not through the window. Throw it in if it pleases you though ;)
Dave8 ( ) posted Wed, 23 February 2005 at 11:16 AM ยท edited Wed, 23 February 2005 at 11:18 AM
refration and reflection
Image Hosted by ImageShack.us the vase it self is not the best but this look looks good on other stuff
Message edited on: 02/23/2005 11:18
anxcon ( ) posted Wed, 23 February 2005 at 11:31 AM
so then i need some tuts for reflection/refraction :)
Tunesy ( ) posted Wed, 23 February 2005 at 1:12 PM
From your first post: "its glass for a window". In that case you don't 'need' refraction normally. A vase is another story.
Aureeanna ( ) posted Wed, 23 February 2005 at 5:44 PM
looks great Dave...care to share how you did it.
Dave8 ( ) posted Wed, 23 February 2005 at 6:15 PM
its all out there in freestuff just look for it and adjust as u need to as it does not look to great if u leave it as it is need sleep have no idea what am saying anymore
Dave8 ( ) posted Wed, 23 February 2005 at 6:36 PM
if ya can wait till l8er i will send the file to ya
this is 2 props using same settings so it can be used on windows just as good as a vase
Aureeanna ( ) posted Wed, 23 February 2005 at 6:41 PM
it's gorgeous! well worth waiting...:>0
