Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 17 6:51 am)
For the template can't you just export the model as an object and then pull that object into uv mapper to make the new template? Also, I have lost stuff on my system, I have two 40 gig drives and a 30 gig backup drive, as well as my pull outs, so I have lost stuff too. If you can get the original name you can do a search for the original downloaded file, I've done that and found stuff too. Old Woman...No Coffee...Can You Tell? lol Marque
pdblake is right. If you have the figure, and want to make an object to map in UVMapper, just export it as an object, and you will have a mappable object file. If, however, the figure can't be open, you don't have the figure, just the cr2 or whatever. Hmm....this doesn't make sense. How can a figure open in Poser without an object? I mean, it's written into the cr2 that it needs an object to reference. scratches her head Hmm......
i have a poser figure but dont have an geom or obj file i need to make a template to texture it i have uv maper how can you export it and keep it poseable after sending it to uv mapper thank you in advance
