Fri, Jan 10, 11:39 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
Subject: Image sizing - Need help
annemarie2 ( ) posted Sat, 26 February 2005 at 7:11 PM ยท edited Mon, 23 December 2024 at 2:25 PM
I am trying to render my contest entry for BlueLotus's "Render my daughter" contest. I am having some problems figuring out how to do the image size for the print ready version. This is what she wants: 300 dpi (pixels: 4,200 x 5,100). Final print size: 14" X 17" minimum. Question is...where is the dpi adjustment? Can I do it in poser 4, or do I have to do it in Poser 5? I know how to adjust the window size I just have no idea about the dpi. Any and all help would be greatly appriciated:) Thanks alot!
SndCastie ( ) posted Sat, 26 February 2005 at 7:17 PM
in poser 4 when you go into render options you can set your render to render in a separate window and change the size and dpi hope this helps not sure on P5 as don't have it. :O) SndCastie
Sandy
An imagination can create wonderful things
SndCastie's Little Haven
annemarie2 ( ) posted Sat, 26 February 2005 at 7:30 PM
is the dpi below the sizing options? Like it says: Width: Height: Resolution: Is the dpi the resolution?
SndCastie ( ) posted Sat, 26 February 2005 at 7:36 PM
Yes the dpi is the resolution that it will be printed at. it is normally at 72 just change it to 300 :O) Make sure you click the little box for rendering in a separate window that opens up the size and dpi to change it. SndCastie
Sandy
annemarie2 ( ) posted Sat, 26 February 2005 at 7:37 PM
Thank you so much :) :) :)
