Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 23 1:20 pm)
in poser 4 when you go into render options you can set your render to render in a separate window and change the size and dpi hope this helps not sure on P5 as don't have it. :O) SndCastie
Sandy
An imagination can create wonderful things
SndCastie's Little
Haven
Yes the dpi is the resolution that it will be printed at. it is normally at 72 just change it to 300 :O) Make sure you click the little box for rendering in a separate window that opens up the size and dpi to change it. SndCastie
Sandy
SndCastie's Little
Haven
I am trying to render my contest entry for BlueLotus's "Render my daughter" contest. I am having some problems figuring out how to do the image size for the print ready version. This is what she wants: 300 dpi (pixels: 4,200 x 5,100). Final print size: 14" X 17" minimum. Question is...where is the dpi adjustment? Can I do it in poser 4, or do I have to do it in Poser 5? I know how to adjust the window size I just have no idea about the dpi. Any and all help would be greatly appriciated:) Thanks alot!
