Tue, Feb 25, 3:11 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Carrara Free Stuff here.
Subject: multiple shaders on a vertex object
Exyled ( ) posted Tue, 08 March 2005 at 2:43 PM · edited Tue, 25 February 2025 at 12:15 PM
how do you add more then one shader to one object. like if I have cube, and I want the front to be orange the left to be blue the back to be red and the right to be purple. The tops can be anything else, how would I do this?
ominousplay ( ) posted Tue, 08 March 2005 at 4:17 PM
This requires selecting the side in the vertex modeler, naming it as a shading domain. Name each side a different name / domain. Then in texture room, apply a layer list. Use parametric for each side, apply each layer a parametric layer - choose the shading domain, apply a color or texture .... just play around with it. You'll need to add six layers for each side of the cube. It took me a while to figure it out, sorry if I didn't explain it well. I'm not at my computer. R.
Never Give Up!
Sardtok ( ) posted Fri, 11 March 2005 at 7:32 AM
Or use a layer list, then add different flat layers, then select the side, and you can use a reference shader to refer to another shader of your choice, or you can insert a color or multi shader into the source.
kelley ( ) posted Sat, 12 March 2005 at 10:45 AM
There's a good exposition of Shading Domains in the Carrara Studio 3.0 Handbook by Mike de la Flor...pages 265-270. I just found it, have not read through it carefully, but he introduces the section by saying that it's really straightforward and easy.
