Wed, Nov 13, 10:57 AM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: Help with this problem
Compo ( ) posted Thu, 10 March 2005 at 7:29 AM · edited Wed, 13 November 2024 at 10:50 AM
http://bb.1asphost.com/lesbutler/long way from home.jpg HELP....You see the lens flare bottom left - 'enable lens flare' is turned on so as to enable a sun, but it ain't causing that large flare. Even with all settings 'off' it's still there. But, it has something to do with that light because if I delete it it's gone. This is driving me insane. So anyone know how to get rid of this effect. I get this all the time when the sun/light is in a similar position.....Thanks for any help - Les.
wabe ( ) posted Thu, 10 March 2005 at 7:51 AM
To me this looks like a sun lens flare. But your description says sort of "no". Could you maybe do a screenshot of the settings per light source - including sun? The little setting to the above right and maybe the lens flare settings. So that we can see what the exact ones are. That would be very helpfull, i am sure.
Compo ( ) posted Thu, 10 March 2005 at 8:47 AM
Thanks. Here's the settings. Lens flare is enabled for the sun, but as I say, even if I pull the slider right back, or turn all settings off, that 'flare' is still there. But...if I delete that light it's gone. I'm using Vue 4.01. Thanks
Rids ( ) posted Thu, 10 March 2005 at 9:14 AM
could well be a version bug, if you are using 4.01 you are way behind on the updates, the current version is 4.22.
Compo ( ) posted Thu, 10 March 2005 at 9:30 AM
Thanks Steve (and for TN reply). I thought .01 was the only update for this version, before 5. I'll grab the highest 4 update off E-on and give it a go. You say on TN that there were a lot of lighting probs with 4, could well be that then. Thanks! - Les
wabe ( ) posted Thu, 10 March 2005 at 9:35 AM
Ok, updating is a good thing too - missed the version number. But i don't think it is a version problem here. I enclose a screenshot from me (Vue 5 german version, but nothing has changed there) so that you can compare.
Compo ( ) posted Thu, 10 March 2005 at 10:09 AM
Wabe thanks for the pic. It was relevant that you say 'point light'. I had used directional light for the sun. I moved the dl, replacing with pl, adjusted settings, and all was okay. So I now know to use pl for sun. That flare issue is still occurant for the dl, but it's out of view. Thanks for the help! Les
wabe ( ) posted Thu, 10 March 2005 at 11:16 AM
Great that it finally worked. Any reason why not using the sun as sun?
Compo ( ) posted Thu, 10 March 2005 at 11:34 AM
I can't see a setting specifically called sun to apply. From the help - "Vue d'Esprit considers the sun as being a pinpoint source of light located at infinity (directional light)." So I used directional light and hence that flare problem. Used pinpoint instead and all was well ;o)
