Sun, Feb 2, 3:42 PM CST
Photography F.A.Q (Last Updated: 2025 Jan 30 8:47 am)
Subject: Just playing with the light box I built...
zhounder ( ) posted Fri, 18 March 2005 at 4:32 PM · edited Sun, 02 February 2025 at 12:48 PM
Attached Link: http://www.pbase.com/wlhuber/light_box
The link is to the plans. I upgraded a bit and used cloth instead of art paper and I bumped the PVC up to 3/4" for stability. These are just a few friends we have around the house. I think I am ready for some paid product shoots now! Magick Michael
#2
zhounder ( ) posted Fri, 18 March 2005 at 4:33 PM
#3
zhounder ( ) posted Fri, 18 March 2005 at 4:34 PM
#4
zhounder ( ) posted Fri, 18 March 2005 at 4:35 PM
crap. forgot the image!
zhounder ( ) posted Fri, 18 March 2005 at 4:36 PM
#5
#6
zhounder ( ) posted Fri, 18 March 2005 at 4:37 PM
And last but definately not least...
Onslow ( ) posted Fri, 18 March 2005 at 4:43 PM
These worked out really well the lighting is great.
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies live;
Their heads are green, and their hands are blue, And they went to sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
tibet2004uk ( ) posted Fri, 18 March 2005 at 4:50 PM
OMG I just love all these miniature gargoyles!! Totally!! Superb shots!
ReBorneUK ( ) posted Fri, 18 March 2005 at 5:14 PM
I knew buying wor lasses Mother that clock was a bad idea.... (",)
cynlee ( ) posted Fri, 18 March 2005 at 5:55 PM
really like 2. & those 2 clock gargoyles!... smoooooooth background, must check for wrinkles... the light box looks like it's working well, although the spot of light in the dolphins doesn't seem diffuse enough?
Michelle A. ( ) posted Fri, 18 March 2005 at 6:32 PM
Just love the gargoyles and dragons! Looks like it's working out well for you!
I am, therefore I create.......
--- michelleamarante.com
DJB ( ) posted Fri, 18 March 2005 at 6:39 PM
Good link too..guess what I will do this weekend if time permits....
"The happiness of a man in this life does not consist in the absence but in the mastery of his passions."
ryno ( ) posted Fri, 18 March 2005 at 7:47 PM
This is so cool, and would save so much time setting up the macros I want to shoot. Yea! thanks I'm convinced I need to build one of these. One question about the shallow depth of field, did you have to shoot wide open because of lack of light, camera/lens limitations, or aesthetic choice? I'm asking to decide what kind of lights to buy. BTW what was your lighting source?
TomDart ( ) posted Fri, 18 March 2005 at 9:34 PM
A portrait studio recently was finally closed after several decades. I noticed that the "flooring" and up the wall was a soft to the feet sheet of stuff. This turned out to be linoleum, a kind with a white side on the bottom. Spread like a carpet and with the white up, it worked quite well. Of course, the standard "grand masters" etc., drops were there too. I wonder how this would work for a small set like you made? Anyway, love the porpoises...that one really works well. Humm...now to build a light box... thanks. Tom.
zhounder ( ) posted Fri, 18 March 2005 at 10:09 PM
ryno, I shot with a 50mm 2.8 Macro lens and yes because of the lighting it was wide open. The light was two bare 60watt bulbs set at the same hight and for the Dolphins a third 60watt behind me and the camera. cyn, I actually ironed it before I shot. The wrikles that are showingare because I didn't smooth it out when I moved the dragon. Gotta watch those details dangit. Also the one side was open to the camera. On the original shots were too flat so I lit a lamp behind me. If I were to re-shoot, I would completely close off the object then open a small whole for just the camera. If you look closely you can see the box and where it ends as well as the bare bulb above and behind me. Magick Michael
cynlee ( ) posted Fri, 18 March 2005 at 10:22 PM
ah well this practice makes perfect down to the littlest detail... that's what i was wondering about, with the light box there should be no bare bulbs reflecting so that explains it & i'm still sold on making something similar
thanks magick for sharing these!! :]
tibet2004uk ( ) posted Fri, 18 March 2005 at 11:11 PM
Can u actually buy these things?? I mean, already made y'know cos, well DIY and I aren't great friends! ;)
tvernuccio ( ) posted Sat, 19 March 2005 at 12:30 AM
Very, very nice Michael!!! they all look great!!! I'm with you, Pascale! I would rather just buy one. i live in a small apartment and don't have space for all that DIY stuff!!!
zhounder ( ) posted Sat, 19 March 2005 at 12:42 AM
Attached Link: http://www.adorama.com/JU7492.html?sid=10698229448952
You can buy them. I am seeing light tables and Cube lights for $250 - $450 at Adorama. This is kind of a combination of both. You can get the high end stuff too its only about $5000. Check the link. PS I built this for $20 not including the cloth backdrops. Three cloth backdrops cost another $70 but I got the best cloth I could find in white, black and gold colors.
DHolman ( ) posted Sat, 19 March 2005 at 1:19 AM
Cool stuff Michael. Would like to add that the stuff I've read on product photography, you almost never want to have your environment reflecting in/on the product unless it's part of the shoot. Most used some type of diffusion material over the whole thing (like a dome) or a flexible piece of white material that could be used as a reflector. Sort of make a half-moon type shape so that it blocks out the room without blocking out the light. That make sense?
tvernuccio ( ) posted Sat, 19 March 2005 at 2:41 AM
$250-$450?? Forget it! that's ridiculous!!!! But thanks for telling me anyway and for the link!!!!!!! I'm gonna ask my dad to make me one for Christmas or something!!! he has huge wood shop, and makes stuff all the time!!! that so much again Michael!!
Michelle A. ( ) posted Sat, 19 March 2005 at 7:55 AM · edited Sat, 19 March 2005 at 7:56 AM
What Donald describes is called a tent..... it not only diffuses the light but also blocks all those extraneous reflections..... which are especially noticable on the dolphins.
Message edited on: 03/19/2005 07:56
tibet2004uk ( ) posted Sat, 19 March 2005 at 8:19 AM
Ah!! Yea, I might as well ask Laurent to make one for me! He's VERY good with his hands! (DIY I mean, don't get the wrong ideas! Well, it wouldn't be THAT wrong but, y'know, it's not the subject here so...oh well!) ;P
DHolman ( ) posted Sat, 19 March 2005 at 8:34 AM
Yea .. a tent. Thanks Michelle. I thought about product photography for all of about 15 minutes. Realized I'd probably prefer chewing on a roll of aluminum foil over photographing products and promptly put those books away. :) -=>Donald
Tedz ( ) posted Sat, 19 March 2005 at 8:57 AM
Far more refined than My Own Light-Box...which I made from a large Card Board Carton obtained from the Supermarket....time for a bit of a spruce up....thanks for the info :]
zhounder ( ) posted Sat, 19 March 2005 at 9:35 AM
Michelle/Donald, They make special "tents" for highly refelctive objects that is usually rounded as to creat total diffused light on the obect. I have seen them in ads and articles but haven't broken down and bought one yet. And yeah its boring work but if it pays enough for a new lens or something, I am willing to get paid to be bored. :)
DHolman ( ) posted Sat, 19 March 2005 at 10:09 AM
Too bad this didn't come up 2 months ago. We just tossed a dozen very large, clear plexiglass domes (half-globes) that we used on our old security system. They were probably big enough to cover a 13" TV. A thin frosting of paint (or plexi etching) to give it a diffuse white and they would have been perfect for this kind of stuff. Ah well.
Michelle A. ( ) posted Sat, 19 March 2005 at 10:13 AM
At this point I'd just like to get paid. Agree with you boring or not it's money! Being unemployed for the last 3 years, any big photo purchases I make have to be justified and run by Mr. Money Pockets before I can buy them. :~/
ReBorneUK ( ) posted Sat, 19 March 2005 at 10:26 AM
Pascale, too much detail!!! Dirty girl... Michael, cheers - this may have come about at the right time. A colleague's husband has asked me to set up a website for his fasteners business.... god knows why, he obviously hasn't seen my past attempts.... anyways, creating a small version of this for the shots might not be such a bad idea... Tom, interesting.... firm yet flexible.. wide but long.... no, not me ;-) Lino!!! Cool idea..... (",)
tibet2004uk ( ) posted Sat, 19 March 2005 at 2:13 PM
LOL@Mike!! So u suck at making websites huh! There's quite a cool web hosting, which is the one I use, and it's also VERY easy to use!! No need to know anything about HTLM and stuff and it's also free! ;) As for being dirty...mmmmh....
ReBorneUK ( ) posted Sat, 19 March 2005 at 6:36 PM
I suggested that, but he wants one where he can at least have some say over the 'style' of the content and not being generic like so many of the step 1-2-3 ones.... They don't offer the flexibility with the graphics that he wants, from the sound of things. I suppose part of me wants to show off too ;-) Just watch him start wanting flipping shopping baskets or summik.... THEN I'll have to start swotting up.... (",)
tibet2004uk ( ) posted Sat, 19 March 2005 at 7:25 PM
Ah yes! True! and what "swotting up" means??
ReBorneUK ( ) posted Sat, 19 March 2005 at 7:51 PM
'swotting up' - researching, usually used in the term of a schoolchild reading notes in anticipation of a test. (",)
tibet2004uk ( ) posted Sat, 19 March 2005 at 7:58 PM
Oooooh! Thx for the translation dear! :D
ebsmooth ( ) posted Mon, 21 March 2005 at 5:02 PM
nicely done Michael, glad to see you stopped cleaning and finished your light rig!!! seems as though it works pretty well, from the results you posted!!! good job boss!!! eb
