Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
Smooth Polygons: OFF?
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD
space
curse that polygon smothing
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
Are you selecting the option in the P4 renders to "Ignore Shader Trees"? If so... then is it a possibility that there is an ambient colour other than black being used. Even with an ambient value of zero, the Poser 4 render engine will render in accordance with the ambient colour if you have selected the option to Ignore Shader Trees.
Message edited on: 03/19/2005 11:31
The problem does not come from the firefly, nor Poser but from the geometry of your cell. It is not "smooth" friendly. Select these objects go to their properties and uncheck the "smooth" option. You could also uncheck the "smooth"option in your render settings but I don't recommend you to do so: you'll loose the smart smooth shape of your character... OK? :)
