Wed, Feb 5, 10:21 AM CST
Subject: Is there somthing wrong with my firefly?
GODspeed ( ) posted Sat, 19 March 2005 at 8:45 AM · edited Mon, 03 February 2025 at 11:57 PM
i render in poser 5 with poser 4 engin.. look great... then when i render to firefly... well.. see for yourself. any clue? im doing nothing to the image beside changing engines.
dlfurman ( ) posted Sat, 19 March 2005 at 8:52 AM
Smooth Polygons: OFF?
DCArt ( ) posted Sat, 19 March 2005 at 8:53 AM
Are you rendering in draft mode?
GODspeed ( ) posted Sat, 19 March 2005 at 8:56 AM
Smooth is off. Render is Production quality
Dave8 ( ) posted Sat, 19 March 2005 at 9:24 AM
u need to take smooth of for each prop or figure as the option in the render settings does not seem to work
Fugazi1968 ( ) posted Sat, 19 March 2005 at 9:42 AM
curse that polygon smothing
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
Ayelmar ( ) posted Sat, 19 March 2005 at 10:46 AM
Eureka! I'll have to try this, because I came here looking for the answer to much the same problem.
(See attached...)
-Timberwolf- ( ) posted Sat, 19 March 2005 at 11:00 AM
Set Smooth Poligons off in render settings .Make sure to use the Poser Service Release 3 or 4 because the render- engine ignore this setting in earlier Releases.
caulbox ( ) posted Sat, 19 March 2005 at 11:28 AM · edited Sat, 19 March 2005 at 11:31 AM
Are you selecting the option in the P4 renders to "Ignore Shader Trees"? If so... then is it a possibility that there is an ambient colour other than black being used. Even with an ambient value of zero, the Poser 4 render engine will render in accordance with the ambient colour if you have selected the option to Ignore Shader Trees.
Message edited on: 03/19/2005 11:31
Olivier ( ) posted Sat, 19 March 2005 at 2:04 PM
The problem does not come from the firefly, nor Poser but from the geometry of your cell. It is not "smooth" friendly. Select these objects go to their properties and uncheck the "smooth" option. You could also uncheck the "smooth"option in your render settings but I don't recommend you to do so: you'll loose the smart smooth shape of your character... OK? :)
Ayelmar ( ) posted Sat, 19 March 2005 at 7:21 PM
By Jove, that's it!!! I turned off the smoothing on my set prop, and all's right with the world! Presenting "Gothika Galactique #1" by Ayelmar! (Special thanks for the following: Set by Awful Soul, hair by Dark Whisper, costume by Danie and Marforno, background image courtesy HubbleSite)
