Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 3:49 pm)
Vethril, I do not recall seeing this prop. I directly modeled, I see the potential for a horrifically large mesh. Unless you are going to pose a figure coming thru it, a two sided plane, with a good texture and transmap may be all that you need. Up close, but not in it, the plane could be sawtoothed in cross section, rather than linear.
I just built a stone wall segment with 24 rounded cubes, saved out of Rhino as .3ds, and the thing came out to be 4 MB when exported from poser as .obj. I need about 20 or so copies of this model for a scene I wanted to do, but when I saw that file size, I said, "(&^#^%(U)))&^$!!!!!" What a wasted effort!
Another idea would be to use one or two flat planes, and then put a "beaded curtain" material on the planes. If you have a good modeling program, you could drape the planes however you want. Transparency mapping would make the space between the beads see-through. That is the best way to keep the size down; otherwwise, like everyone said, your model will get horrifically large. Wish I could point you to the right material, but I haven't seen one like that yet. Might not be hard to build though, if you have a good paint program. Just draw 6-10 beads on a string, and then replicate a lot. Seems like the material would be straight and the 3d aspects would come from how you put ripples and curves in the object itself. Or you could model 6-10 spherical and ovoid shapes in a modeling program; render them out, and use them as the bead models in your paint program. Hope PhilC solved your problem and you're already rendering!
Attached Link: Magnificent Dreams
![file_143065.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_143065.jpg)
Has anyone seen a prop for a "beaded curtain" to use in a doorway? I am trying to make a scene, and thought I remembered one somewhere on the net, maybe here at Rosity. But I can't find one to use. Would appreciate if anyone can point me towards one. Thank you kindly, and enjoy the day. =)
