Wed, Jan 22, 5:03 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 2:19 pm)
Subject: P6 and removing the Content Room
Indoda ( ) posted Fri, 25 March 2005 at 11:19 AM ยท edited Wed, 22 January 2025 at 5:00 PM
Does the trick that was used for P5 work for P6? I tried it but must have missed something as it came back by itself!! Is it worth the hassle? TIA
The important thing is not to stop questioning.
- Albert Einstein
Indoda
Gareee ( ) posted Fri, 25 March 2005 at 11:33 AM
Yep, it works.. here's the link to poserpros, and Neitherworks excellent pdf on how to do it: http://poserpros.daz3d.com/forums/viewtopic.php?t=16569
Indoda ( ) posted Fri, 25 March 2005 at 11:42 AM
Thanks Gareee I knew there was a .pdf somewhere was trying to do it from memory. Memory is failing ;(
- Albert Einstein
Indoda
Gareee ( ) posted Fri, 25 March 2005 at 11:51 AM ยท edited Fri, 25 March 2005 at 11:51 AM
I saved it in my documents, and also saved the link, in case I forgot it. (it was reposted somewhere recently)
No if I HAD the frickin thing so I could remove content paradise from it.. LOL!
Message edited on: 03/25/2005 11:51
RealDeal ( ) posted Fri, 25 March 2005 at 1:20 PM
can anyone give a synopsis? I don't feel like signing in to poserpros today.
Gareee ( ) posted Fri, 25 March 2005 at 1:29 PM
You don;t want a synopsis for screwing around removing the room. get Nietherwork's pdf from the link.
kaveman ( ) posted Fri, 25 March 2005 at 3:56 PM
Yes, it works but it doesn't give you that speed boost P5 needed while loading. So there's no performance advantage in doing it. YMMV.
Gareee ( ) posted Fri, 25 March 2005 at 4:02 PM
I imagine ther has to be some speed increase beacues you are not loading resources. Plus, when working, every bit of memory is worth retaining.
hein ( ) posted Sat, 26 March 2005 at 7:07 AM
Synopsis:
1: MAKE A BACKUP OF POSERSHELL.XML before you mess around
2: Open /...runtime/ui/posershell.xml in a texteditor , completely remove the 3 lines that contain "ContentRoom" , save
Gareee ( ) posted Sat, 26 March 2005 at 7:16 AM
except there are more then just 3 lines that say content room to be removed.
hein ( ) posted Sat, 26 March 2005 at 7:26 AM
A search in the XML only found 3 , removing those 3 lines was enough.
Gareee ( ) posted Sat, 26 March 2005 at 7:29 AM
did you read the faq at the link I provided? Check the last entry to delete.. it's about 5 lines..
hein ( ) posted Sat, 26 March 2005 at 7:48 AM
If I set my texteditor to wrap at #80 I get 5 lines too, the link points to a log-in screen, not going to register to yet another board. Since removing the 3 or 5 lines worked fine here, even without reading the faq, I thought I'd mention it.
Gareee ( ) posted Sat, 26 March 2005 at 8:11 AM ยท edited Sat, 26 March 2005 at 8:12 AM
I'd just hate to see someone screw up thier poser install, because they were too lazy to read a complete walkthough. And of course now we've both wasted both time and bandwidth, reposting in essence exactly what the link I provided had in it. And I think it's already been reposted here at rendo about 20 or so times.
Message edited on: 03/26/2005 08:12
RealDeal ( ) posted Sat, 26 March 2005 at 10:35 PM
Ahh, but at least I did not have to sign in to poserpros! the thread was a success for me! * this post is not version specific
Gareee ( ) posted Sun, 27 March 2005 at 7:31 AM
Yeah, but you could have had the information 2 days ago, but was too lazy to go get it yourself.
