Mon, Feb 3, 1:01 AM CST
Subject: Question: realistic grass.
daeve ( ) posted Sat, 20 January 2001 at 5:28 PM ยท edited Mon, 03 February 2025 at 12:53 AM
How do I make realistic grass on a terrain or imported object? The above picture is a terrain generated in the terrain editor in Bryce 4. I need to be able to make good grass on the islands.
daeve ( ) posted Sat, 20 January 2001 at 6:04 PM
This is sort of the idea, I hope Judy doesn't mind if I use this as an example.
jade_nyc ( ) posted Sat, 20 January 2001 at 9:17 PM
I would write to her and see how she obtained this effect - but my guess would be that she did this in post after rendering - the only way I've found to get realistic grass is to either use a picture texture or to paint it in yourself during postwork - if I'm wrong though let me know because I would sure be interested in how she obtained this grass in Bryce. Jade
ironbrew ( ) posted Sun, 21 January 2001 at 5:57 AM
Attached Link: http://www.3dplants.com/
Try this link for some excellent grass and plants
Apache2k ( ) posted Sun, 21 January 2001 at 2:00 PM
Attached Link: http://members.nbci.com/eetu
Hi there,, I had the same problem, but i think another way. Its nice but if u want to have very close views than it sucks. The grass in the picture was made with this style. First create a terrain. Go to Terrain edit and new. Take the grid of 512 Click the Spikes effectten times. Now you can edit the shape or multicopy or resize as u wish. You just have to make this in a nice looking scale. Have a nice day. I hope this will help.
jade_nyc ( ) posted Sun, 21 January 2001 at 7:41 PM
You can also use your 2D program, like Photoshop, to make some noise and use that to make a terrain, but like Apache's spike method, it doesn't really work for closeup grass. Jade Jaded Images - http://jade3d.posermail.com
adamite ( ) posted Mon, 22 January 2001 at 3:15 AM
1.Make a symmetrical lattice, go into the terrain editor, set the mesh density to the lowest or second lowest resolution, and draw a nice grass blade, maybe a very slightly curved line, make sure it is a shape good for a side-on profile of your grass blade, get out of there, flatten out your lattice nice and thin, and rotate it until its the right way round. 2.Make your material for your blade now. 3.Duplicate this lattice until you have a clump of grass. 4.Now rotate and position these individual blades around till this grass patch has a slightly random/natural character. 5.Bear with me, because this technique looks really good if done correctly. 6.group and then multireplicate or hand duplicate this group. 7.make sure you tweak the rotation,size,density and position of your duplicate groups every so often to induce a more random/natural appearance. 8.Do the step above until you feel you have enough grass, position your groups or groups of groups from the top view, until they cover the areas you want covered. 9.ungroup all the grass groups go to the align icon, open its little menu, press snap to ground. 10. Group all the grass lattices and move the group up until it is above ALL the terrains it has to cover.(You must only have the terrains that you want covered in grass in your scene until you finish doing all these steps.) 11.Make sure all the lattices are just above the highest points of all your terrains, ungroup the lattice group, go to the align menu, press "SNAP TO LAND". 12.Try this technique, render...it is worth the effort, but make sure your blade shape and material are just right from the start...
JetM ( ) posted Sat, 03 February 2001 at 1:13 PM
You can also go to 3dplants.com. There are some absolutely fabulous free downloads of plants, among them grass. You can import the objects and scatter them about your scene. There's a CD to purchase as well, which I'm seriously thinking about getting now that I've played with the downloads
