Thu, Jan 9, 1:36 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 09 12:26 am)
Subject: wierd things happening in this Poser 6 render - please help
zulu9812 ( ) posted Mon, 28 March 2005 at 4:37 PM · edited Wed, 25 December 2024 at 5:27 PM
very early WIP here. Two things bugging me, both of which should appear to be fairly obvious. The first is that Poser 6 is rendering things beneath the ground plane - how to stop this? Secondly, there's the great friggin' huge things behind his head. This is with smooth polygons turned on, with it off it's just a line. It appears as a dotted line in Preview, and does not seem selectable with the mouse - however hard I try. I think it might be something to do with the katana prop, but I'm not sure what. Any thoughts?
wheatpenny ( ) posted Mon, 28 March 2005 at 4:42 PM
Site Admin
I don't know about the artifact on the head, but the problem with the floor can be fixed by making the ground plane visible (select the ground plane and check "visible"). This works in Poser 5 and should in Poser6 as I don't think this is one of the things they changed - but I don't have P6 yet, so I can't check.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
maxxxmodelz ( ) posted Mon, 28 March 2005 at 5:01 PM · edited Mon, 28 March 2005 at 5:04 PM
"This works in Poser 5 and should in Poser6 as I don't think this is one of the things they changed - but I don't have P6 yet, so I can't check."
The ground plane in P6 is "on" by default, but is set to "catch shadows only", which makes it display ground shadows only, while the rest is invisible on render, and will not "occlude" objects beneath it. You need to disable shadow catch in the material room for the ground, and attach a diffuse map (if you desire), which make it opaque. Message edited on: 03/28/2005 17:04
VacuousSapient ( ) posted Mon, 28 March 2005 at 5:39 PM · edited Mon, 28 March 2005 at 5:40 PM
It is my understanding that to fix a lot of the things in 6 (and there are a few) you will need to be sure and have your video drivers and bios up to date.
Also try bringing your rendering down on the video card. I updated my video and with the new drivers I am able to allow the application to control the settings.
Might be worth trying.
Message edited on: 03/28/2005 17:40
feldermaus ( ) posted Mon, 28 March 2005 at 6:59 PM
I don't own P6 and I reserve the right to be mistaken but.... If the hair is a prop that is parented to the head, turn off the "bends with parent" option in the parent pull down. Another quick fix is to alter the rotation slightly. What you are seeing looks like sheer and it used to be common in 3d programs. I hope this helps, Bob
nerd ( ) posted Mon, 28 March 2005 at 8:50 PM · edited Mon, 28 March 2005 at 8:51 PM
Forum Moderator
If the head artifact is part of one of the props you'll probably have to use the grouping tool to create a new prop without the extra polygons. It inflates with smoothing on because that's how polygon smooting works. You can turn the smoothing off for just that object, but you should try to fix the offending prop.
You'll probably want to work on the prop seperately, fix it then add the fixed prop to your scene.
The ground. If you want the ground to be visible in renders take the check of "Shadow Catch Only" for the ground in materials.
Nerd3D
Message edited on: 03/28/2005 20:51
