Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
Maximum: 1000 particles;
Frequency 1000 +- 2000;
Lifetime: 3,00 +- 2,00
Velocity: 2,00 +- 1,00
Size: 0,30 +- 0,00
Use the TOXEs smoke shader and good steam. ;-)
Yes I do have shader ops Toxe but, from that point I need to be led by the hand every inch of the way.--every milimeter! Shader ops and your amazing shaders are I suggest areas in which many Carrara users havent a clue on using effectively. Good tutorials are urgently needed. I am in awe of all you clever people. Brian
bwtr
Well probably some are dumber than others but, after using C2, 3 and now 4pro, I have just discovered the "apply to children" button. And when things still would not work I changed background colour. OK I'me a bit closer to grasping things--I only need them spelt out 2 millimmeters at a time-but perhaps it highlights that many of us are at a very low point in the learning curve and really do need things spelt out. Brian
bwtr
