Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
kilal, GREAT NEWS! How did you do it? 1) Did you need to select an older Poser exe like Poser 4 or 5? 2) Did you install Transposer 2 after Poser 6? 3) Was any other version of Poser installed? last one 4) Did you need to install the Transposer 2 plugin twice? Good Job!, Appreciate any additional details. Steama
Hi! It's me again! I finally understand what happened with transposer2. I can't import any file if i don't select poser 5.exe when i import
a figure for the first time.If a figure have ever been imported by poser5 exe, the next times i can select poser6exe and it works well.At this time i don't know if animations are imported correctly.On my first try the body animation was ok but not the face morphs.I received poser6 yesterday in the morning .just beginning the tests .
Have nice day ! kilal
The new closeup is done in Carrara4Pro .Any way transposer2 doesn't work properly with poser6 in fact i used
poser5 exe to import.You can understand that poser5 exe doesn't have a full compatibility with poser6 characters,problably there some informations missing or misunderstood by poser5 exe.The best thing to do is to wait for transposer2 update:-)
I was told by someone at Eovia that Transposer 2 does not use the Poser.exe file that Transposer 2 wants you to select in order to import a Poser file. Transposer 2 uses its own Transposer 2 Poser Run Time to open the Poser file (I bet it is based on Poser 5 SDK). Transposer 2 simply wants you to select a Poser exe to verify Poser is there in order to bring in a Poser file. So I guess that means that the programming in Transposer 2 is based on Poser 5 SDK, therefore, it is not totally compatible with Poser 6 (doesn't even recognize it as a Poser.exe file). As stated in this thread even Shade is not 100% compatible either with Poser 6. Steama
So they can make a Transposer 3 for importing Poser 6 files in time for Poser 7. :)
I noticed that Poser 6 is now shipping. Does anyone in the community know if Poser 6 plays nice with Carrara's New Transposer 2? I know I may be a bit early with this question but I was wondering before I purchase Poser 6. Thanks for any info provided...
