Tue, Feb 18, 12:06 PM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 7:53 am)
Subject: OK NOW I'm mad at Curious Labs for the state of P6
StealthWorks ( ) posted Sun, 03 April 2005 at 3:25 PM · edited Tue, 18 February 2025 at 12:01 PM
I stopped the render that had taken 11 hrs so far (see the post below) thinking I would have beautiful reflections etc and THIS is what I get???? The next few posts will illustrate just how BAD the firefly renderer is. This first post shows the render settings I used. If I am doing something wrong can someone please tell me!
Curious Labs, a question for you. What is the point of adding all these wizzy new features such as ambient Occlusion, IBL, sub surface scattering if the BASICS are broken???
OK first of all here are the render settings
StealthWorks ( ) posted Sun, 03 April 2005 at 3:28 PM
OK this next one is a closeup of the face. What ARE these black lines across it. They appear elswhere in the image and I know they were there in P5. WHy can't you fix this CL - this is a basic rendering problem?
StealthWorks ( ) posted Sun, 03 April 2005 at 3:30 PM
THis is a reflective vase. Look at the edges. This looks positively ridiculous. As If I'd cut and paste the vase from another image.
StealthWorks ( ) posted Sun, 03 April 2005 at 3:31 PM
This last pic is of the area under a chair. Where on earth did this criss-cross pattern come from. ANd I attached a reflection node to the metal stand on the chair. Why is there NO reflections. Explain yourselves Curious Labs????
NEThingbutNOcent ( ) posted Sun, 03 April 2005 at 3:35 PM
Try turning off texture filtering? That may help with the jagged edges and lines?....
nakamuram ( ) posted Sun, 03 April 2005 at 3:57 PM
11 hours!! What kind of system do you have and how complex is your scene? Try these settings: Leave texture filtering on. You could reduce max size to 1024, but 2048 should be OK. Increase your bucked size to 32 or 64. Decrease you pixel samples to 3 and your post filter to 1. Check Smooth Polygons and Remove Backfacing Polygons.
UrbanChilli ( ) posted Sun, 03 April 2005 at 3:58 PM
I had that problem in P5 already. No one could really come up with an solution, so I only render automatics settings in P5 and the presets in P6. I think that rendering in firefly takes a deep look into the manual.
anxcon ( ) posted Sun, 03 April 2005 at 4:01 PM
i dont click "full render" now, as i dont trust my comp i do area renders, and since my latest pic i made was at 16384x12288 (2^14, 4:3) i figured my comp would die lol so doing area renders, and its a simple paste job in psp each pic new layer, white background is transparent worked great now you may ask why so big? no idea ^_^ i blame insanity anyways that might help you out with long renders so it wont stop in middle, plus you can go with stronger settings, and save between renders to avoid uh x_x
StealthWorks ( ) posted Sun, 03 April 2005 at 4:12 PM
Actually the scene isn't that complex. 1 Poser figure, a reflective vase and a reflective chair. I have a 3.2HT P4 machine with 2GB of RAM. Yes 11hrs seems a bit excessive but I was putting that down to a fault with Poser6. Also, if I incerase the bucket size then I get the out-of-memory error! Needless to say I'm very frustrated. I didn't have nearly as much problem with Poser5 and it was definately quicker.
UrbanChilli ( ) posted Sun, 03 April 2005 at 4:12 PM
WOW! Thats really big, I do max renders at 2400 x 2400 and that it only if theres going ot be a lot of post.
williamsheil ( ) posted Sun, 03 April 2005 at 4:13 PM
Also change the shading rate to 0.5 or lower and set the minimum displacement bounds to 1 or 2 (pixels) as that may remove the lines in the image if they are an artifact of displacement on the materials. I probably wouldn't increase the bucket size more that 8 or 16 if its a very complex scene. Bill
anxcon ( ) posted Sun, 03 April 2005 at 4:25 PM
2.8E GHz cpu, 512mb ram, win98, 1 girl, 1 chair, 1 mirror raytraced shadows, raytrace at 6, bucket at 32 30 pixel samples, cut into 8x8=64 parts, 9 hrs total not one problem entire time :)
CandeeKis ( ) posted Sun, 03 April 2005 at 5:02 PM
Im not having any problem rendering beautiful images in P6 In fact the sharpness and clarity in P6 is beautiful! Here are two examples(to follow) comparing renders in both P5 and P6 versions. POSER 6 FIREFLY RENDER (which didnt take that long either...certainly not even close to 11 hours - more like 5 min)
CandeeKis ( ) posted Sun, 03 April 2005 at 5:03 PM
Comparison to the Poser 5 render
Gareee ( ) posted Sun, 03 April 2005 at 5:06 PM
Hmm and I notice the same thing in all other P5-P6 comparisons.. the P5 version is sharper!
CandeeKis ( ) posted Sun, 03 April 2005 at 5:10 PM
You think Gareee??? See I look at these and see more sharp and vivid colors on the P6 render.
operaguy ( ) posted Sun, 03 April 2005 at 5:19 PM
stealth1701, Can you start with something very small and simple? Just a shot of your female character with no props, maybe even nude, turn off texture filtering, turn off raytrace (unless you have some raytrace lights) and just render out to a small final size, like 300x500 or something? Just to get a successful final and see if you effects are working? What lighting do you have in place? I just find that in a new environment to create a small success and guage the neighborhood, then gradually increase the complexity. ::::: Opera :::::
StealthWorks ( ) posted Sun, 03 April 2005 at 5:23 PM
operaguy I am using ambient occulsion and image based lighting which is maybe why the render takes so long. i can render without raytrace etc. without a problem but obviously I need it for reflections. Problem was, from the time it was working to the time it started looking like this, I just changed some lighting to spot light and then back. For some reson whatever I did upset the firefly renderer. I think I need to go back to a working version and try changing things one at a time. I don't think I can get rid of the lines as it is a throwback to P5, but I'm very annoyed CL hasn't fixed this yet.
Gareee ( ) posted Sun, 03 April 2005 at 5:24 PM
Yeah Candee... look at the buttons specifically.. the P5 ones look sharper and more detailed then the P6 ones. I do think there's more depth and vibrance in the P6 version, but also a loss of detail. Looks like either transparency or translucency is a bit different in P6 renders, based on her shawl
Gareee ( ) posted Sun, 03 April 2005 at 5:30 PM
Yep.. here's a closeup of both.. I saved both images, cropped them close to the same area, and then just increased the entire image size about 300% Looks like P5 is sharper, but also possibly has more noise as well?
kuroyume0161 ( ) posted Sun, 03 April 2005 at 5:44 PM
It looks that the vibrance is caused by the 'bleed' or bluriness of the texture. You lose some vibrance with sharpness, but you get sharpness. :) Personally, the P5 render is better. I've been noticing that the P6 Firefly renders appear more like paintings because of this bleed.
 -- Bjarne Stroustrup
Gareee ( ) posted Sun, 03 April 2005 at 5:47 PM
Yeah I kinda prefer the P5 render as well. I can always add blur in photoshop, and kick up the color some to make it hotter. There may be a setting we're al missing as well, that might eliminate the blurring. Also, rendering "up" to a larger image, and then downsizing might be a good P6 option.. that might look better thjen the P5 version, too.
bevans84 ( ) posted Sun, 03 April 2005 at 7:34 PM
I don't know if this is on point or not, but I'm thinking that the renders are different because the render settings or the scenes aren't the same. A while back, I made a small scene to look at some new purchases. For grins, I made the scene in P5, saved as a pz3, then loaded it into P6 and rendered with the saved settings. There was absolutely NO difference, not even a pixel (that I could find). I timed each render, and even that was the same. FWIW
PapaBlueMarlin ( ) posted Sun, 03 April 2005 at 7:55 PM
In P5, decreasing the bucket size made the render faster. Why would increasing the bucket size in P6 decrease render time?
maxxxmodelz ( ) posted Sun, 03 April 2005 at 9:02 PM
"I've been noticing that the P6 Firefly renders appear more like paintings because of this bleed." Changing the kind of post filter type you use might help increase overall sharpness. Box is probably the worst to use, and gaussian is best for animation, but many people don't bother to change it from the default. All my final renders, for instance, are done with sinc, and I think they come out quite detailed and sharp.
maxxxmodelz ( ) posted Sun, 03 April 2005 at 9:06 PM
"In P5, decreasing the bucket size made the render faster. Why would increasing the bucket size in P6 decrease render time?" It's always been that decreasing bucket size helps save on memory, but sacrifices speed. At least that's what I recall Stewer saying a few times.
Tashar59 ( ) posted Sun, 03 April 2005 at 9:24 PM
I notice the difference but I also think it's a matter of learning the new version.
gtrdon ( ) posted Sun, 03 April 2005 at 9:46 PM
Yeah I noticed my renders were far more vibrant in P6 than P5 using IBL with default..But there was a loss in detail crispness in my characters facial features... I wish I could have both maybe its going to take some tweaking which I hope I or someone else will figure out because I really love everything else about it...
svdl ( ) posted Sun, 03 April 2005 at 9:58 PM
No reflections? I'm not surprised, you have to enable raytracing to have reflections. The amount of pixel samples is pretty high, that means a lot of antialiasing, up to the point of blurring the complete image. For a sharp render I usually use a value of 3-5 pixel samples. The black lines are often eliminated by checking displacement maps and setting the displacement bounds to 1.000. Choosing another bucket size also often helps. Gaussian or sync filter are also better than box filters, though they are slower. Gaussian gives the best results in my opinion, though sync is better with strand-based hair. I'd suggest looking up the render options in the manual and see what they do. By applying a balanced set of options the renders usually look fine.
My gallery   My freestuff
12rounds ( ) posted Mon, 04 April 2005 at 2:11 AM
Stealth wrote: "I have a 3.2HT P4 machine with 2GB of RAM." Your issue may be related to hyper-threading. As far as I've seen most render-oddities with P6 are happening to people who have hyper-threading processors. If hyper-threading is causing Poser difficulties to render, I'd say you're out of luck until a service release is made available by CL.
Berserga ( ) posted Mon, 04 April 2005 at 8:13 AM
I wonder if it isn't texture filtering that is causing all these blurry comparison shots? I noticed that the highest auto settings automatically turn it on, which Ronstuff at least would say is a no no. (and will mess up V3 texture seams if you don't doctor the textures your self.) I also noticed that the default shading rate in the top pic was set WAAAAY too high. Try .5 at least. I also agree about the post filter setting. Box sux bigtime. as for black line artifacts, these have just shown up in some of my shots in Poser 5. Nobody has come up with a reason. It seems very random as the same exact setup shot from a different angle may have no artifacts. On the plus side It doesn't happen very often. also 11 hours sounds INSANELY too long. I've rendered whole animations with multi figures and raytraced reflections in that time. admittedly that was at 853x480 though.
