Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 24 1:33 pm)
Are you rendering out to individual frames, or trying to go directly to .avi? If rendering out to individuals, if the process halts at any point you can start it from where you left off. The only issue with individual frames is that you have to import them into a video editing app (I use Quicktime Pro, $29.99) to assemble into a vid. Is your page file (virtual memory) set to 1.5 Gig? That's usually the rec., 1.5 times the physical RAM. It is always a good idea to do this before a major render: Exit Poser Reboot. Do not launch any programs, including browser and email. Make a 'safety' copy of your pz3 Go back in Check render settings Render
Hi... I tried all the night to get a 300x300 movie of my character's head in poser 5 .. first with a total of 50 frames then of 35.. it was simply impossible to finish the rendering. it always stopped at ~30 frames on "creating frame : 30" and then i can wait .. 2 hours and it doesn't change.. Can someone help ? I have 1go RAM and enough disk space.. I had once a message that I hadn't enough virtual memory, so I put it "system controlled" on 2 disks ...
