Tue, Feb 18, 4:33 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Subject: problems changing the render dimensions in P6
zulu9812 ( ) posted Wed, 06 April 2005 at 10:10 AM · edited Tue, 18 February 2025 at 4:32 AM
This is all rather frustrating. I'm trying to render a 15-frame animation at a size of 140 pixels x 140 pixels. I change the render size to 140x140 in Render Settings. On the Make Movie screen, I have the resolutions set at 140x140. But when I use the Make Movie screen to render the 15 frames they are all rendered at 550x550. What gives? At the moment I'm having to render & save each frame individually and it's a pain in the arse.
Talisman ( ) posted Wed, 06 April 2005 at 10:32 AM
Are you saving the movie file as .avi or image files? I think rendering the movie as image files saves the size. Try pps 348-349 in the manual, maybe the clue can be found there.
zulu9812 ( ) posted Wed, 06 April 2005 at 10:42 AM
sorry, forgot to mention that I was saving as image files
DCArt ( ) posted Wed, 06 April 2005 at 11:42 AM
Choose Render > Render Dimensions. You set dimensions for renders in a separate window now. You choose Match Preview Window, Fit in Preview Window, or Render to Exact Resolution.
zulu9812 ( ) posted Wed, 06 April 2005 at 11:49 AM
That's what I did - Render to Exact Resolution
DCArt ( ) posted Wed, 06 April 2005 at 11:52 AM
OK, after that you go into the Movie Settings tab of the Render Settings dialog. There are dimensions there as well that might be affecting your render settings.
zulu9812 ( ) posted Wed, 06 April 2005 at 12:06 PM
Yep, done that - still renders the images to 550x550. It seems as though the quick render size section (the bit where you select Full, Half, Quarter or Preview) is overriding manual settings.
DCArt ( ) posted Wed, 06 April 2005 at 12:14 PM
OK ... I set the document window to 550 by 550. In the Render Dimensions window, I selected "Render to exact resolution." Then I clicked the Match Document Window button, and checked "Constrain aspect ratio." Then I changed render dimensions to 140 by 140. I choose Animation > Make Movie. Format AVI, Renderer Firefly. In the Resolution section, I unchecked "constrain aspect ratio" and manually entered 140 by 140. Then I put "Constrain aspect ratio" back on. (For some reasons this didn't change automatically when I set up the render dimensions stuff.) Anyway, after doing all that, the Full render dimensions do display 140 x 140.
zulu9812 ( ) posted Wed, 06 April 2005 at 4:44 PM
Mmm...still no joy...thanks for your help btw. I tried rendering to an avi and a series of bmps. Still gives a pic size of 550x550. I'm attaching screenshots of render dimensions and movie settings screens, if that helps.
zulu9812 ( ) posted Wed, 06 April 2005 at 4:45 PM
always forgetting the files...
zulu9812 ( ) posted Wed, 06 April 2005 at 4:46 PM
and again
