OK ... I set the document window to 550 by 550. In the Render Dimensions window, I selected "Render to exact resolution." Then I clicked the Match Document Window button, and checked "Constrain aspect ratio." Then I changed render dimensions to 140 by 140. I choose Animation > Make Movie. Format AVI, Renderer Firefly. In the Resolution section, I unchecked "constrain aspect ratio" and manually entered 140 by 140. Then I put "Constrain aspect ratio" back on. (For some reasons this didn't change automatically when I set up the render dimensions stuff.) Anyway, after doing all that, the Full render dimensions do display 140 x 140.
This is all rather frustrating. I'm trying to render a 15-frame animation at a size of 140 pixels x 140 pixels. I change the render size to 140x140 in Render Settings. On the Make Movie screen, I have the resolutions set at 140x140. But when I use the Make Movie screen to render the 15 frames they are all rendered at 550x550. What gives? At the moment I'm having to render & save each frame individually and it's a pain in the arse.
