Thu, Jan 30, 12:15 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 10:50 pm)
Subject: Losing Y rotation
LonRanger ( ) posted Fri, 08 April 2005 at 5:06 PM ยท edited Thu, 30 January 2025 at 1:03 AM
I am running into this in P4(PP) and P6. I am losing the Y rotation. When I choose a figure's body and attempt a Y rotation, instead it does the Z rotation -- and when I use the Z rotation, it is the Z rotation, and the X rotation is fine as well. I have noticed this with V3 in PP and when importing a PP project with V3 into P6. Anyone else running into this?
stewer ( ) posted Fri, 08 April 2005 at 5:28 PM
Attached Link: http://www.anticz.com/eularqua.htm
Do you have a 90 or -90 degree rotation in X by any chance? If so, you've just discovered the gimbal lock, a nasty side effect of xyz-rotations. One thing you can do about it is open the joint editor and change the rotation order to something that suits your situation better.
LonRanger ( ) posted Fri, 08 April 2005 at 5:41 PM
You're right. My figures are set at near 90 degree rotation in X (although not exactly 90). When I stand the figure up, the Y rotation is back. I did find a work around which is to stand the figure up before moving it to the new position, since this gives me the Y rotation back. Thanks for the help!
