Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 08 9:05 am)
Well if you want high/broadcast quality forget rendering to avi for starters... You need to render to images (try png or tga cuz they allow for alpha channels) and then assemble your image sequence to video with a external application, I use VirtualDub because it's easy, fast & free! NTSC DVD resolution is 720 x 480 by the way... I always render at 1024 x 768 and my mpeg encoder (MainConcept MPG encoder) reduces it to the 720 x 480 so I suppose the extra initial resolution is just quality assurance!! Hope this helps! Gerard
The GR00VY GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
"(try png or tga cuz they allow for alpha channels)" It's true that .tga retains alpha channels, but Poser doesn't render to .tga files for animation (unfortunately). However, you can render to .TIFF, which retains alpha as well, and is supported by most video editing software.
Tools : 3dsmax 2015, Daz Studio 4.6, PoserPro 2012, Blender
v2.74
System: Pentium QuadCore i7, under Win 8, GeForce GTX 780 / 2GB
GPU.
The problem with PAL and NTSC is that they're both interlaced formats and as far as I'm aware Poser doesn't export fields. I export as PSD files, export this as a sequence into After Effects and render that using fields. This still isn't perfect, it can produce a lot of jagged edges and it's depressing the amount of vertical blur I have to put on to cure this.
Am I understanding this correctly....I should export to individual images - there for I will have 25 images per 1 second (for PAL). Then I merge them in an external program such as VirtualDub. Is this correct? Just to reafirm what I want to achieve. I want to overlay a model that is walking over a video scene. In the video, there is a doorway, and I want to make it appear the model walks in the doorway. I thought I could uses a mask of some sort that masks out the models when it gets to the doorway. I hope this makes sense. Cheers.
"Am I understanding this correctly....I should export to individual images" Always. Unless it's for preview or testing purposes. "I thought I could uses a mask of some sort that masks out the models when it gets to the doorway." You could mask it off in post using a decent video editing/FX software. I'm assuming you want part of the rendered model to be concealed behind the doorway (at least in part)? It can be done in post.
v2.74
GPU.
"Can you explain jsut a little how I would achieve this in post?"
It can be a little complex if you've never done it before, and without getting into an entire tutorial on how it's done in this thread, the basic gist would be to mask off a particular area of your background, and use layers to composite it over the figure. There's other meathods to achieving this as well, some better than others. My advice would be, if it can be done in your software, to do a search on Google for masking and compositing for that software.
"Which programs should I use? or should I say which one do you guys use?"
I wouldn't wanna tell you what you should be using, because it's a matter of preference to the individual. However, I would recommend something like Adobe AfterEffects or Discreet Combustion to do intermediate to advanced video compositing like you want.
Personally, I use Combustion 3.
v2.74
GPU.
"How do I export my poser movie so that the end result is all the image files?"
You don't export them like you would still images. You need to "make a movie". So go to 'Animation/Make Movie' in your menu at the top, then select "Image Files" as the type. Message edited on: 04/11/2005 04:57
v2.74
GPU.
you can try this tool too, opensource. http://avidemux.berlios.de/forum in the windows forum.
Attached Link: http://www.pegasys-inc.com/en/index.html
DVD is a whole can of worms, trust me I am working on my own movie and have researched this thouroghly.Once you have edited your movie (I use Ulead Media studio Directors cut) But there are any number of editors available, that will work.
You will need an MPEG 2 encoder. I use TMPGEnc, It supports a very important flag in the MPEG 2 standard That can tell a DVD player to do it's own 3:2 pulldown on the fly which means YOU DO NOT have to interlace your video if this flag is set. This will save TONS of space on your disc for higher quality video, AND It will alow for PROGRESSIVE SCAN play back on a progressive scan TV.
I'm also not sure which DVD authoring software will allow you to author a progressive discs, so you will want to research that, to see how much you want to spend Versus the features you need. I use TMPGEnc DVD author which supports all the features of the encoder. I also got their 2.0 (Stereo) AC3 encoder. (Again to save disc space and Maximise compatibilitty with DVD players.) TMPGEnc DVD author lacks a few Bells and Whistles but It is very inexpensive, and it's the easiest to use authoring software I have tried. It also was the most compatible with multiple DVD players. JUST DON'T USE THE BUILT IN BURNING SOFTWARE, Use something like Nero, especially if you want to get your DVD replicated commercially.
Now if you don't have any of this software, you might want to look into Sony VEGAS+DVD, It's a top notch Video editing software with capable DVD authoring and best of all the ability to mix and encode 5.1 AC3! I couldn't justify the cost or come to grips with the editor's interface, but if you are not used to anything else already you might want to go that route. It is MUCH more expensive than the software I use though.
Oh and if you want to make your DVD widescreen (It's the way of the future man) Render at 853x480. The DVD player will automatically letter box it on a 4:3 TV, But it will fill a 16x9 TV. :D
BTW I have rendered test discs, so all this info is accurate. The 3:2 pulldown even worked with a Playstation 2.
Message edited on: 04/11/2005 09:07
Message edited on: 04/11/2005 09:11
Attached Link: http://www.discmakers.com/film/
BTW You can get 1000 DVDs commercially replicated, with packaging and printing included for $1.75 a disc... It's actually cheaper than self publishing a comic these daysAttached Link: http://www.poserguide.nimprodaction.com/
to create your own DVD i suggest you read POSER GUIDE issue 2.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hi, I have been playing around with Poser and I am loving it - but I don't find the pdf guide very useful. How to I export to hi res DVD and Broadcast quality. I know how to export to AVI but don't know how to get hi quality. Thanks. Mil
