Tue, Feb 4, 12:03 AM CST
Subject: Vue 3 Water and query on Windows 98
jetstream ( ) posted Mon, 18 April 2005 at 4:46 PM ยท edited Tue, 04 February 2025 at 12:01 AM
I have Vue 3 and am experimenting with water effects. At the moment the water scenes I have generated in Terragen seem to have more realistic surfaces especially waves . Would I be right in thinking that you can't edit water in Vue3 in the same way you can edit terrain? Any help greatly appreciated - I have some fine 3DS Warships just waiting for a stormy sea!
Is Vue 4 a worthwhile upgrade BTW and can it run on Windows 98?
agiel ( ) posted Mon, 18 April 2005 at 6:58 PM
Attached Link: http://www.e-onsoftware.com/Products/vue4/Requirements.php
Here are the requirements for Vue 4 - Windows 98 is supported. You cannot edit water the same way as terrains, but you can apply a water material to a terrain if you want your water to have a particular shape (other than a flat surface).
kevin_c ( ) posted Tue, 19 April 2005 at 2:35 AM
I just recently upgraded from 3.1 to 4 and I have to say that the water is MUCH better in Vue4. With 3.1 the water was always flat. No sign of even small waves. In Vue4 it seems to automatically apply slight waviness to the water which is usually the type of effect you are looking for. Vue4 has a lot of other advantages too including easier terrain editing and stable animation.
jetstream ( ) posted Wed, 20 April 2005 at 7:07 AM
Thanks . It sounds like Vue4 is a lot more realistic fr water . Mind you the terrain trick sounds like its worth a try.
jetstream ( ) posted Wed, 20 April 2005 at 10:40 AM
Thanks for the terrain idea , Agiel ! Heres my first try at using it
