Sun, Jan 5, 11:57 AM CST
Renderosity Forums / MarketPlace Showcase
Welcome to the MarketPlace Showcase Forum
Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Jan 01 5:01 pm)
Welcome to the MarketPlace Showcase Forum. The Showcase Forum and Gallery are intended for all commercial related postings by active Renderosity MarketPlace Vendors only. This is a highlight area where our membership is invited to review in greater detail the various art products, software and resource site subscriptions available for purchase in the Renderosity MarketPlace.
Subject: Poser 6 obj file effeciency. All Merchants should see this.
byAnton ( ) posted Sun, 24 April 2005 at 4:31 PM · edited Sun, 05 January 2025 at 11:54 AM
Attached Link: Fragmented OBJ files
I discovered a very common problem to us all which could potentially affect mesh product render times for some Poser6 users.
It has to do with spam within the obj file format that can ghappien during the mapping/grouping process.
Regards,
Anton
Message edited on: 04/24/2005 16:35
-Anton, creator of Apollo Maximus
Over 100,000 Downloads....
ClintH ( ) posted Sun, 24 April 2005 at 6:06 PM
Hi Anton, Nice to see you around. Thanks for the link. Clint
Clint Hawkins
(Zakk Wylde (2007))
byAnton ( ) posted Sun, 24 April 2005 at 6:10 PM
Thanks. np. SOme people don't have this issue with firefly. Also not all obj files are fragmented. It can be a figure or a prop or an imported obj. Basically it is just about some people having a hang on the firefly calculation that reads the materials from the mesh on rendering. This particular issue has a very specific symptom being a long hang on the "adding objects" status bar. Using a script or utility for defragmenting the obj g/usemtl lines is really just another thing people should do during content creation, like adding a white backdrop to a texture, etc. It just gets added to the list of things to check for when building a product.
dialyn ( ) posted Sun, 24 April 2005 at 6:34 PM
For the techno-ninnies like me, how would I know that the problem is fragmation? I read the explanation but for me, it doesn't mean much. I understand very little about how these things work. I am referring to products we already have. With any luck, merchants will be working on correcting that.
byAnton ( ) posted Sun, 24 April 2005 at 6:40 PM · edited Sun, 24 April 2005 at 6:42 PM
For me, the symtom is a very long hang when the "adding objects" status bar comes up. The bar should only appear briefly after the "adding textures" status bar. If you are encountering a long hang as described then it may be this issue.
You may not have any problems at all. It seems to be a firefly/hardware calculation or something so not everyone may run into this. But for some it can make a product a joy or a pain to work with. If you go to the thread and use Spanki's program to resave the obj(always make a backup), and the hang goes away, then contact the author so they are aware in making future items.
Message edited on: 04/24/2005 18:42
dialyn ( ) posted Sun, 24 April 2005 at 6:42 PM
Excellent suggestion. Thank you.
byAnton ( ) posted Sun, 24 April 2005 at 6:47 PM
Np. I am just glad I ran into it on my system. Otherwise I would never been curious enough to dig into it.
faveral ( ) posted Sun, 24 April 2005 at 10:19 PM
Thanks for the tip. I'll make sure I STOMP my objs from now on !
Andi3d ( ) posted Mon, 25 April 2005 at 2:47 PM
question....is this an .obj specific problem? or can it affect .pp2/cr2 files with embedded geometry?
 "That which doesn't kill you is probably re-loading"
byAnton ( ) posted Mon, 25 April 2005 at 4:50 PM
Andi3d, I am not sure. For some reason I don't think it would do it with embedded geometries. I am not sure though.
Spanki ( ) posted Sat, 30 April 2005 at 3:06 PM
"question....is this an .obj specific problem? or can it affect .pp2/cr2 files with embedded geometry?" I also don't know, but suspect the oposite of Anton ;). Another reason not to use embedded geometries.
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
