Mon, Feb 3, 2:39 AM CST
Photography F.A.Q (Last Updated: 2025 Jan 30 8:47 am)
Subject: F-Stops f/2.8 to f/13
azy ( ) posted Tue, 26 April 2005 at 1:46 PM · edited Sun, 02 February 2025 at 11:58 PM
If anyone interested I took these shots from f/2.8 to f/13 to show the difference in the background. How different f-stops can isolate you subjects by throwing the background out of focus. The 1st one f/2.8
Eggiwegs! I would like... to smash them!
f/3.5
azy ( ) posted Tue, 26 April 2005 at 1:47 PM
f/4.0
f/5.0
azy ( ) posted Tue, 26 April 2005 at 1:48 PM
f/7.1
azy ( ) posted Tue, 26 April 2005 at 1:49 PM
f/10
f/13
cynlee ( ) posted Tue, 26 April 2005 at 1:54 PM · edited Tue, 26 April 2005 at 1:59 PM
thank you azy!!!! yes... these should be helpful here :] edit: fyi (from the resource center) f-stop: Used to define the aperture settings on a lens (the opening within the lens that allows light through). F-stop numbers are arranged in a series of stops (a doubling or halving of any value) numbering 1, 1.4, 2, 2.8, 4, 5.6, 8, 11, 16, 22, 32. Some lenses may have more, some less - but each numerical value is a stop, that is, it either doubles or halves the amount of light allowed to pass through the lens. (Note: the larger the number, the smaller the opening, therefor less light.) Larger numbers (less light) increases depth of field. The actual numerical values are a ratio of physical aperture opening to focal length of the lens (i.e., f4 on a 50mm lens would be a physical opening of roughly 12.5mm in diameter - 50/4=12.5).
Message edited on: 04/26/2005 13:59
azy ( ) posted Tue, 26 April 2005 at 1:57 PM
Then I moved closer and got the shot I wanted F-stop f/20 ISO 100 Shutter Speed 1/4 sec
TwoPynts ( ) posted Tue, 26 April 2005 at 2:32 PM
Perfect! Thanks for posting this, you just made things clearer for a lot of people I'm sure...pun intended. ;]
TomDart ( ) posted Tue, 26 April 2005 at 6:37 PM
Very good post! This is the sort of stuff lot of folks need..up close and personal with images "witnesses" Thanks.
BrockLawson ( ) posted Tue, 26 April 2005 at 10:49 PM
I was actually going to ask about this earlier today but had to run. Glad to see this. THANK YOU!
DJB ( ) posted Tue, 26 April 2005 at 10:53 PM
Now that last one is the shot i would want too. Thanks for the settings.
"The happiness of a man in this life does not consist in the absence but in the mastery of his passions."
BrockLawson ( ) posted Tue, 26 April 2005 at 11:29 PM
Ok what am I doing wrong? When I set my Camera to f/2.2 I get more DoF then when I set it to f/8.0.
tvernuccio ( ) posted Tue, 26 April 2005 at 11:31 PM
Thanks for posting to show the difference! i love your photos!!! verrrrry nice. my cam can only go up to f8. sigh.
neverfinder ( ) posted Wed, 27 April 2005 at 1:27 AM
One question was that thing dead ^^ ;-) cause normally I don't get so much time shooting them. @brocklawson the DOF stays the same in the viewer of the camera only the final image changes.
jimry ( ) posted Wed, 27 April 2005 at 3:06 AM
Thanks Cindy for the Aperture values and settings....might help some here :)
Onslow ( ) posted Wed, 27 April 2005 at 4:59 AM
Excellent illustration of dof :)
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies live;
Their heads are green, and their hands are blue, And they went to sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
Erlik ( ) posted Wed, 27 April 2005 at 7:08 AM
Umm, if I may note something... If your camera is anything like mine, these had to be shot at different focal lengths, right? I cannot get 1.8 (no, it's not a mistake, 1.8) except at the widest setting. The more you go towards tele lengths, the smaller is the aperture. (Generally speaking!) Wide angle has nicer side sharpness, while tele has nicer depth sharpness. So the blurring depends on that. Which would be kinda confirmed by your pics, no? Or I'm wrong?
-- erlik
Michelle A. ( ) posted Wed, 27 April 2005 at 8:18 AM
If I were to guess..... These were shot with a DSLR, and a lens with a fixed maximum aperture. Fixed focal length or zoom it would not matter.....
I am, therefore I create.......
--- michelleamarante.com
azy ( ) posted Wed, 27 April 2005 at 10:13 AM
Michelle is right These were shot on a Canon 350D using a Sigma 105mm macro lens so there was no zoom. I should of said this at the start but I was pushed for time. I might try this again using diffrent subjects and lenses.
ReBorneUK ( ) posted Wed, 27 April 2005 at 12:26 PM
ok, aze, you is either VERY fast, that fly was VERY slow (read:asleep) or you're a wizard with superglue! Whatever, excellent demo mate, even I can understand when I see it like this.... (Cyn, cheers also - me being lazy I wouldn't have found that for myself, and it helps too!) (",)
BrockLawson ( ) posted Wed, 27 April 2005 at 10:47 PM · edited Wed, 27 April 2005 at 10:51 PM
Ok my Sony DSC-f828 is backwords. I checked to make sure I didn't put the pictures backwards or anything. Maybe I am doing something wrong I am not sure.
First Picture:
Shutter Speed .2 f/2.0
Second Picture:
Shutter Speed 10 seconds f/8.0
So am I doing something wrong or is my camera really backwards?
Message edited on: 04/27/2005 22:51
BrockLawson ( ) posted Wed, 27 April 2005 at 11:07 PM
My camera's manual says... Open the aperture... The subject is clear and its background is blurred. Close the aperture... The subject and background are both clear.
Michelle A. ( ) posted Thu, 28 April 2005 at 7:25 AM
You're not doing anything wrong, and your camera is not backwards. Large opening = small number.... example f/2.8 You open up the aperture, dof becomes shallower less area is in focus or clear. Small opening = larger number.... example f/16 You close down the aperture, dof becomes greater, more area and background is in focus or clear.
BrockLawson ( ) posted Thu, 28 April 2005 at 10:45 AM
Wow I feel stupid now. :( Ok it just clicked now that I looked at the original photos again. Thanks!
