Photography F.A.Q (Last Updated: 2025 Jan 30 8:47 am)
thank you azy!!!! yes... these should be helpful here :] edit: fyi (from the resource center) f-stop: Used to define the aperture settings on a lens (the opening within the lens that allows light through). F-stop numbers are arranged in a series of stops (a doubling or halving of any value) numbering 1, 1.4, 2, 2.8, 4, 5.6, 8, 11, 16, 22, 32. Some lenses may have more, some less - but each numerical value is a stop, that is, it either doubles or halves the amount of light allowed to pass through the lens. (Note: the larger the number, the smaller the opening, therefor less light.) Larger numbers (less light) increases depth of field. The actual numerical values are a ratio of physical aperture opening to focal length of the lens (i.e., f4 on a 50mm lens would be a physical opening of roughly 12.5mm in diameter - 50/4=12.5).
Message edited on: 04/26/2005 13:59
Perfect! Thanks for posting this, you just made things clearer for a lot of people I'm sure...pun intended. ;]
Excellent illustration of dof :)
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies
live;
Their heads are green, and their hands are blue, And they went to
sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
Umm, if I may note something... If your camera is anything like mine, these had to be shot at different focal lengths, right? I cannot get 1.8 (no, it's not a mistake, 1.8) except at the widest setting. The more you go towards tele lengths, the smaller is the aperture. (Generally speaking!) Wide angle has nicer side sharpness, while tele has nicer depth sharpness. So the blurring depends on that. Which would be kinda confirmed by your pics, no? Or I'm wrong?
-- erlik
If I were to guess..... These were shot with a DSLR, and a lens with a fixed maximum aperture. Fixed focal length or zoom it would not matter.....
I am, therefore I create.......
--- michelleamarante.com
Ok my Sony DSC-f828 is backwords. I checked to make sure I didn't put the pictures backwards or anything. Maybe I am doing something wrong I am not sure.
First Picture:
Shutter Speed .2 f/2.0
Second Picture:
Shutter Speed 10 seconds f/8.0
So am I doing something wrong or is my camera really backwards?
Message edited on: 04/27/2005 22:51
You're not doing anything wrong, and your camera is not backwards. Large opening = small number.... example f/2.8 You open up the aperture, dof becomes shallower less area is in focus or clear. Small opening = larger number.... example f/16 You close down the aperture, dof becomes greater, more area and background is in focus or clear.
Eggiwegs! I would like... to smash them!
